Ford Sierra Saloon bootlid gas strut mod
Old 21-07-2016, 06:56 PM
Jack and the Beanstalk
Jack and the Beanstalk's Avatar
Default Ford Sierra Saloon bootlid gas strut mod
Hi All
Has anyone tried to mod the bootlid on a sierra/sapphire saloon to operate with gas struts rather than with those annoying spring loaded boot/trunk hinge springs?
Also on that note the mod for the bonnet struts?
Will be interesting to do if haven't done before. I was thinking of bolting a bracket with ball nut where the spring is attached on the 3 hole bracket and then attaching the other end with another ball nut to where the other end of the spring is attached?
Thoughts?
Old 21-07-2016, 07:30 PM
Ade
Fast Ford snapper
Ade's Avatar
Anything better than the stupid old floppy springs would be good!
Old 05-09-2016, 11:07 AM
nicolai23
nicolai23's Avatar
Default Just the same thoughts in Denmark
Hi.
I'm just working with the same idea in Denmark. Going to test it in my 2,0 dohc sierra.
It is important that the gas strut has started to get longer just when the bootlid is closed. In this way the gas strut pushes to keep the lid closed, when opening the lid the gas strut are pushed pass the shortest point and start to push the lid open.
What spoiler do you have on your Sierra?
Wkr Nicolai Tolstrup, Denmark.
Old 05-09-2016, 05:14 PM
Originally Posted by nicolai23
Hi.
I have sierra sapphire cosworth spoiler. Where will you attach the ends ?
When you have successfully completed this mod. Would you mind posting up some pics please
Cheers 🍻
Old 05-09-2016, 09:46 PM
cossynut2
cossynut2's Avatar
Is it really that much of a pain? How often are we opening the boot? Its never bothered me in the last 21 years of owning my 2wd and I personally dont like trying to make an old car "modern". Boot full of speakers, dvd players etc in the headrests have never been for me but if that is what others like fair play to them.
I did a gas strut conversion on my Sons Subaru Impreza WRX STI bonnet but its a modern car compared to our 30 year old Saffs.
Old 06-09-2016, 04:00 AM
Well Ford should've thought of it. They designed alot of things that contributed to revolutionising car motoring.....almost. I mean abs, electric windows. Electric sunroof, heated seats, power steering, height adjustable seat belts, adjustable steering, good styling and in some later granada models airbags. Why didn't they do something simple to help people when opening Car bonnets and boots. Most of these aspects are found in modern cars, even still today.
Old 06-09-2016, 06:37 AM
cossynut2
cossynut2's Avatar
I guess when Ford were designing the Sapphire it wasnt considered a problem. How many other saloon cars built at the same time had gas strut bonnet or boot openers?
Old 06-09-2016, 07:28 PM
Adam-M
Adam-M's Avatar
My only grudge with the springs is the crude noise they make while expanding lol, other than that they operate fine I suppose.
Old 18-09-2016, 05:19 PM
costina
Live long and prosper!!
costina's Avatar
Pull them to the next notch.
Sorted
Old 14-01-2017, 05:47 PM
iansoutham
OCD Victim
iansoutham's Avatar
Been there, tried it, don't bother.
To make it look anywhere near factory the angles would be all wrong and the strut would hit the underside of the shelf. At the same time, the strut would push the boot lid up from the boot rubber.
Even mounting the strut to the shelf itself would not work as the hinge goes too high when open.
A strut, when compressed, needs to be 2/3 of the extended length to work. When the hinge is lowered, it is almost 1/3 of the length which is too little to make the boot close or open properly.
The reason that they used the springs was for these reasons. The Granada which utilises a strut has different angles.
The nearest I found was the MK4 Escort Cabriolet strut, but this leaves the bootlid only 3/4 open when fully extended.
massivewangers
21-03-2017 08:49 PM
B16CVH
26-07-2016 08:01 PM
bicko
Ford Mondeo Including ST
20-07-2016 12:42 PM
Maxwell
21
18-07-2016 09:22 AM
Fraggle...
17-07-2016 09:41 PM
Quick Reply: Ford Sierra Saloon bootlid gas strut mod
