Low boost help.
Old 12-07-2016, 08:03 PM
Harryh24
Harryh24's Avatar
Default Low boost help.
Hi my engine was bench mapped was peaking at 29psi, I have a stack boost gauge and its only reading 20 psi.
I've checked boost hoses all are brand new, all vacuum pipes Amal valve is working as it should.
What else can I check?
Car runs fine on boost no fuel smell or misfire.
Tia
Old 12-07-2016, 08:33 PM
Sierrasideways
Sierrasideways's Avatar
You could increase actuator preload and see if it helps.
Old 12-07-2016, 08:47 PM
Harryh24
Harryh24's Avatar
Hi yeah I know that but if was bench dyno and that hasn't been touched I cat see it being the cause of the problem if you know what I mean.
Old 12-07-2016, 09:08 PM
Sierrasideways
I know what you mean and it makes sense what you're saying alright. Is the boost pipe going to the gauge tightened on the gauge okay and do you have another gauge to test? If you disconnect the actuator to amal hose I think you should only get actuator spring pressure of around 12psi if using a -31. Could try that I suppose.
Old 12-07-2016, 09:18 PM
Harryh24
Harryh24's Avatar
Yeah the gauge I've got is brand new. Just pulling my hair out lol
Old 12-07-2016, 09:23 PM
Sierrasideways
Not too sure what else to do so! Maybe someone else can help
Old 13-07-2016, 11:22 AM
Mad_Mat
New Owner
Mad_Mat's Avatar
If nothing has changed since bench dyno and assuming you have no air leaks then amal valve would be my bet.
Try another valve and make sure it is jetted the same as the current one.
Old 13-07-2016, 09:13 PM
Harryh24
Harryh24's Avatar
Yeah it was my thought as well, to be honest don't have another to hand to test
Jim Galbally
Technical essay Archives
23
12-09-2016 12:21 PM
Marc D
13-03-2016 08:12 AM
18-12-2003 09:19 PM
Danny B
21-11-2003 12:13 PM
turbochrissy
04-10-2003 09:23 AM
Quick Reply: Low boost help.
