Sierra 3 door
Old 06-07-2016, 08:57 AM
Kingabe
Kingabe's Avatar
Default Sierra 3 door
Right,
Finally after owing a mint xr2 and a bodged together rs turbo I'm in a rwd ford! It's only a base model sierra though but at least it's a 1984 3 door 1.6L with a 2.0 pinto, type 9 etc 😁. It's got focus coilovers on the front, Question is do I / can I just buy rear suspension listed as sierra cosworth 3 door? Noting states just a 3 door. I'm just after lowering it on the rear so springs and shocks?
Stuart
Old 08-07-2016, 10:47 PM
steppy
steppy's Avatar
Regular Sierra hatch or saph shocks and springs will fit on the rear, if you still have the standard rear axle and opt for cosworth shocks you will have to drill the lower shock mount bigger on the arm as the cosworth shock uses a larger diameter bolt
Old 08-07-2016, 10:49 PM
Kingabe
Kingabe's Avatar
Cheers mate, appreciate the help! ��
cos elle
33
31-01-2018 05:18 PM
Gary @ RS CLASSICS
18-03-2016 05:02 PM
siscossie
29-02-2016 06:32 PM
Dan_RS500
28-02-2016 07:07 PM
User 32922
30-11-2003 04:50 AM
Quick Reply: Sierra 3 door
