throttle position sensor
Old 12-06-2016, 10:48 AM
jimhc
big jc
jimhc's Avatar
Default throttle position sensor
What symptoms does a faulty tps or one needing set cause.
Old 13-06-2016, 09:36 PM
martysmartie
martysmartie's Avatar
It will cause hesitation when accelerating and can cause bad idling.
Martin
Old 14-06-2016, 07:30 AM
jimhc
big jc
jimhc's Avatar
Thanks for reply. Last night I checked the volts last night with multimeter and mine seems the wrong way rounds
closed 4.69
open fully 0.49
Old 15-06-2016, 07:28 AM
Guinnless
Guinnless's Avatar
What ECU? And are you on a TPS01 or TPS09 ?
Old 15-06-2016, 09:58 AM
jimhc
big jc
jimhc's Avatar
09 with 2wd ecu. I spoke to PJ Motorsport and are sending me a 01
Old 18-06-2016, 10:47 AM
martysmartie
That is why, PF01 contains a switch, which your ECU needs.
Martin
Old 18-06-2016, 01:06 PM
pectelboy
pectelboy's Avatar
All you need is the converter lead from anembo , swaps the wires over , l8 run 09 and l1and l6 run pf01
Old 21-06-2016, 01:37 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Does the lead provide a constant resistance at idle too so the L8 / P8 ECU doesnt flag a TPS error at key on? That will be handy if so.
Old 21-06-2016, 03:12 PM
jimhc
big jc
jimhc's Avatar
I've fitted the Pf01. What should it read?. Also the idle seems to be crazy if I plug in the idle control sensor but was fine before strip down been cleaned and so has my spare but revs still go to 2500.
Old 21-06-2016, 07:28 PM
pectelboy
pectelboy's Avatar
Had one on my cossy , and no fault on the pectel monitor , so must be ok ?
Old 21-06-2016, 07:45 PM
grcossie
grcossie's Avatar
Look here, for sensor reading
http://bigturbo.co.uk/
Old 22-06-2016, 09:13 AM
Cool, must have some circuitry in it to provide a permanent resistance to give the correct PF09 idle output then. I will look into it as that will be handy from time to time.
Im drained of cars coming in with L8's / P8's and PF01's with the wiring reversed moaning that their idle speed is crackers or the ISCV no longer works and the emissions are illegal, along with black fuel on overun etc etc...
day_dreamer
15-06-2016 05:01 PM
jason3249
12-06-2016 10:45 AM
MK5 ESCORT
03-06-2016 08:27 PM
Shaunc
01-06-2016 04:56 AM
timsrs
14-05-2016 06:29 PM
Quick Reply: throttle position sensor
