trattling
trattling
hallo cosworth owners
i could use your advise for a coupkle of issues i have with my 2wd cossy
well its been sitting for the last 3 months . now back on the road i heAR a lot of tapping even after agood run. and occasionaly smoke from the excaust. my oil prerssure is about 20 psi at idle and hot. could the lack of oil pres effect the hydraulic tappets ? i ll be measuring iol pres tomorow straight from the block is ther anything to look out for?
i ll be changing the oil tomorow using an engine flush liquid for 10 15 minutes before drain just in case ther is sludge or oil deposites blocking if this dont help then its sump . my pressure is round 20 25 warm and rises with the revs
the mistake i did 3-4 dayw ago was pooring in some additive for noisy valve lifters- tappets, which probably blocked somethintg thatw why i wanna use the flush to waterfy the oil the valve additive i poor in
L1AM_RS
11
30-04-2016 08:24 AM
