Powerflex strut top mounts
Old 23-05-2016, 09:18 PM
Matty_C
Matty_C's Avatar
Default Powerflex strut top mounts
Fitted these to my car approx 2 years ago when I carried out a resto on it and have covered less than 2000 miles in it, recently when driving to and from shows I've noticed when I turn left the car makes a rubbing noise when going towards full lock, only when I turn left.
Narrowed it down to the near side strut top mount and it's the Powerflex rubber mount causing the rubbing. It was quite dry so I've sprayed it to lubricate it but it's still making the noise. Remove it from the top of the strut completely and turn the wheel and the noise goes. Not sure if it's a dudd rubber mount it still looks new?
Anyone else experienced the same issue? I'm contemplating going back to the ford ones.
Matthew
Old 25-05-2016, 11:58 AM
Marc sierra
Marc sierra's Avatar
It's probably the bearing at the strut top instead of the strut top bush.
Old 25-05-2016, 12:08 PM
cozzy jeff
cozzy jeff's Avatar
Matthew
they are shit them bushes,i put them on my 3dr and when putting the plate on the top they pushed out like jelly,they came straight out and I went for escort cosworth ones which are great.
cossiestu (22-07-2016)
Old 25-05-2016, 03:44 PM
tosh
tosh's Avatar
Hade a similar thing with mine a while back, I just copper greased them all up again and the noise stopped.
Old 22-07-2016, 10:13 PM
cossiestu
cossiestu's Avatar
Had poly ones on for a while, they fitted ok, just regularly ate the bushes...
Old 23-07-2016, 04:14 PM
1374lee
1374lee's Avatar
I have used the group N kit from Woodford, always been fine.Can buy the complete kit or just bush/bearing whatever you need.
Thanks. Lee.
Old 27-07-2016, 01:46 PM
Cossy Mike
Cossy Mike's Avatar
I bought Powerflex and they were also shite, not even the same shape.
They didn't fit right and come in 2 parts, I sold them on and went with Group N bush which is the Escort Cosworth bushes, still available from Ford by the way for £11 each
Old 27-07-2016, 04:44 PM
1374lee
1374lee's Avatar
Wow Mike now that is interesting. Can you PM me the part number please Mike? Cheap and Ford don't go hand in hand normally..lol.
CheeRS.Lee.
Old 27-07-2016, 09:16 PM
Cossy Mike
Cossy Mike's Avatar
CheeRS.Lee.
Sierra mount is 6150277
Escort mount is 6720387
Exactly same mount only harder compound.
Group N means standard class so it's a standard bush
Old 28-07-2016, 10:19 AM
1374lee
1374lee's Avatar
Great info Mike.I have also been looking for the escort group N rear beam bushes, Woodford used to sell them but cannot get hold of them anymore. I wonder if the escos genuine Ford beam bushes also Group N? I don't want to fit poly beam bushes hence the alternative I would like ideally.
Thanks. Lee.
Old 28-07-2016, 11:00 AM
Cossy Mike
Cossy Mike's Avatar
Thanks. Lee.
http://www.ebay.co.uk/itm/GENUINE-FO...EC_OKn9GHMGPXA
This is a joke ^^ £11 from FORD
http://www.ebay.co.uk/itm/GENUINE-FO...3D310868133288
This is a joke ^^^ £12 from FORD
Woodford garage are out to make money simple as. I'd never use them again, I was told they had an O ring I needed for my modine, they priced at £5 plus post as they were NLA
I was charged £8 delivered, then I ordered one up from Ford as a spare and it came at 61p
Group N is simply standard nothing more - that's how it come from the factory, easy way to add extra value
Quote FIA - 'In relation to motorsport governed by the FIA, Group N referred to a set of regulations providing 'standard' production vehicles for competition, often referred to as the "Showroom Class".'
The rear beam bush was around £22 each from Ford a couple of years ago
Old 28-07-2016, 07:01 PM
1374lee
1374lee's Avatar
Great info Mike, I bought the complete kit from Woodford £75, 2 bearing, 2 cups and 2 bushes. I will try Ford 1st then for sure.
You mention the rear beam bushes from Ford do you mean the sierra ones or later escos ones like the top mounts bushes we disgussed? I was hoping the escos items are also group N, hence upgrade on standard sierra beam bushes if you see what I mean.
Thanks. Lee.
Old 28-07-2016, 09:16 PM
Cossy Mike
Cossy Mike's Avatar
Thanks. Lee.
I only ever looked at Sierra stuff Lee
Maybe someone else will know, maybe check numbers from Ford?
Old 29-07-2016, 10:27 AM
1374lee
1374lee's Avatar
Yes I will check with Ford to see if part numbers are different for sierra and escos beam bushes.Thanks for your help Mike, much appreciated.
CheeRS.Lee.
Old 01-08-2016, 07:22 PM
1374lee
1374lee's Avatar
Rear beam bushes NLA from ford for sierra and escos according to my parts man Mike.
Thanks. Lee.
Cossy Mike (02-08-2016)
Old 02-08-2016, 09:45 PM
Cossy Mike
Cossy Mike's Avatar
Thanks. Lee.
Where they the same part though Lee?
Old 03-08-2016, 03:31 PM
1374lee
1374lee's Avatar
I will check later Mike, I don't think they were the same part number from memory. I will report back later on.
ordered my front top mounting kit(bearings,cups and bushes) around £50 for the lot, much cheaper than Woodfords £75.
Thanks. Lee.
Old 03-08-2016, 07:08 PM
1374lee
1374lee's Avatar
Mike, the rear beam bushes for escort and sierra part numbers are different, both NLA.
Sierra Rear Subframe Outer Bush 6141919 NLA
Escort Rear Subframe Outer Bush 6791604 NLA
I just checked my invoice and the front top strut mount cups, bearings and group N bushes came to around £43 from Ford which is almost half the price Woodford is charging.
Thanks. Lee.
Old 03-08-2016, 09:13 PM
Cossy Mike
Cossy Mike's Avatar
Thanks. Lee.
Sorted, that's good to hear
Now you know how they make there money
Old 04-08-2016, 07:46 PM
1374lee
1374lee's Avatar
Yes great help that Mike on the group N bush type and saved my a fair few £££££s.
Thanks again. Lee.
muz
04-12-2019 09:53 AM
27
23-03-2016 06:52 AM
Danielbetty
14-03-2016 10:55 AM
PAUL S
11-03-2016 10:52 PM
lockie
07-03-2016 05:02 PM
Quick Reply: Powerflex strut top mounts
