100mm airtec coolers
I THINK they are some of the better ones before you go for full blown Garret core as per the spec r ones.
Do they perform any better than the Airtec 70mm 500 style version??
Cheers Paul
Cheers Paul
You would hope that the thicker the core the better the cooler?
If you wanted to improve a cooler I think you can get a fabricator to weld wings on to it to scoop the air in and not let the air rush around the sides of he cooler, in effect sealing it to the front of the car.
The Airtec is a good cooler, just not up to the standard of £1000+ coolers like the spec R one which has the benefit of the scoop plus is shorter (lower height) and therefore leaves more air to flow in to the radiator / and or air filter.
I've gone thicker because that's all I could do.
I get that about diminishing returns BUT you could argue that 100mm will still cool better than 75mm as even if the last 25mm is not as efficient as the first 75mm then at least if 1% efficient then still doing more?
I doubt my intercooler will cost me much over £500 when done and it was all completely bespoke. When you look at how much some of the inferior coolers cost it's a lot for not a lot!
Garrett have so many sizes as well.
turbotrev (25-05-2016)
I think mine may be going to spec r but he hasn't responded to my text to see how he is getting on with my little swirl pot....
Run a airtech 100mm on mine, bit of a pain to fit as few mods needed, but it is good and a fraction of the price of a spec r without having too wait. Obviously its not going to be as good but wenny runs one on his mk3, that does 9's all day long and puts out almost 800hp so thats good enough for me.It has a scoop at the front to direct air to it too.
lee2cossies (31-05-2016)
I have to admit that this is very tempting to avoid the pain of the spec r one in terms of lead times, having the car there for 3 weeks and delays, I am sure the bespoke spec r would be better as he can suit it to my 205 front end and mount the rad to it and force as much air through it and not around it but a bit of tig welding on that airtec one would see a lot of that done. As you say Wenny doesn't seem to be hampered much.
I can see that has the scoop on it, what are people's thoughts on adding some ally mounting points to it and seal rubber from the cooler to the front bumper inlet part of the car so that you are sealing the air to only go through the cooler? I thought of rubber to allow for vibration and engine movement?
I was thinking of rubber where I have highlighted and moving the number plate to a sticker on the bonnet
I know a chap who owns a company that makes the rubber face masks for fighter pilots who could do the correct spec of rubber for it
205 looks amazing nice colour aswell
Caddyshack (28-05-2016)
I have ordered one of the 100mm ones as a stop gap until I can send mine to spec R, I can monitor the temps and see if they are within acceptable levels and always sell it on when I upgrade, I am sure it will be better than my RS500 cooler and allows a bit more room to spin the air filter over and have it sucking in cold air through the grill. I may experiment with sealing the rest off with rubber or flexi carbon sheet.
cossie fan (unluckerly)
Which ever way you go out on the road it's going to work. But fact is real life data proves the expensive core in the spec r one produces far lower charge air temp. If your mapper likes to work with low temps to keep things safe and on point with high horse power cars then you don't have much choice if you want what he tells you he can get with certain parts.
I bet if you compare the charge air temps of a car at the end of a very short 1/4 mile with one out on the road on a sunny day flat out in 4th the difference in temps would be shocking over the two cores
We will see soon enough, I have data logging on the ecu using the toucan. Rod was getting negative on his spec r iirc
Ha. My thoughts exactly. I had someone else say the same about the Garrett core, as good as they might be You won't get those results without adding something else.
I've seen between 5-7 degrees above ambient on a intercooler we chose for a customer. It wasn't expensive either. That's logged via a calibrated sensor on Syvecs so I personally see the Airtec unit as more than adequate in reality and for Cost
Going by the experience and know how of the man who built tuned and took the readings that intercooler made I'd say recalibrating the sensor would be pointless and the results they quote what ever they are will be right
You'd think you'd need to be doing 80mph in -10degree weather in order to achieve -temps on the intercooler. It is impressive, was the car just sitting stationary while this was recorded?
I suppose that with 'negative temps' it was meant in comparison to ambient temperature and not below 0. But even lower than ambient sounds a bit strange to me. You are cooling air with ambient air, how can the cooled air be colder than the air that you are using to cool?
I took negative as output temp being less than the cooling air temp.
Highly unlikely IMO.
Intercooler sprays would have a surface cooling effect on the Intercooler, however, nothing like this was mentioned.....
And the discussion was on intercooler performance comparisons.
Rod will need to answer that one, maybe I am mis-quoting him?
BMG
11-05-2016 09:04 PM
xr2john
12
23-04-2016 11:28 AM
