4x4 Rear Brake Calipers help needed
Old 19-04-2016, 04:21 PM
Caddyshack
Caddyshack's Avatar
Default 4x4 Rear Brake Calipers help needed
Hi All, I need to find a rear left hand caliper 4x4 for vented discs as I have a failed hand brake cam in mine (unless someone thinks there is a fix)
I thought I found a pair on ebay but waste of time seller and no goods.
My hand brake is sticking on on that side
the calipers have all new sliders and seals, it is just that the handbrake will not return...could this just be a weak spring?
Old 19-04-2016, 07:15 PM
Ridgey
Ridgey's Avatar
Probably needs pulling apart and new seal on the mechanism itself.
Has the full caliper been refurbed or just sliders and which seals?
Old 19-04-2016, 07:26 PM
Caddyshack
Caddyshack's Avatar
Just slider n seals, piston seal etc. I will look at rest, thanks
Old 19-04-2016, 07:54 PM
The Youth.
The Youth.'s Avatar
if you have a good quality G clamp and patience you can overhaul them yourself, freeing off the handbrake arm is really easy with the right tools, i've done loads over the years,
wind piston out then push down on cage and spring with clamp and remove circlip then pull out cage then remove a second circlip and threaded adjuster, then withdraw handbrake arm, clean and regrease and refit
steve
MONSTER (20-04-2016)
Old 19-04-2016, 08:04 PM
Caddyshack
Caddyshack's Avatar
Thanks, I will do that
Old 19-04-2016, 10:22 PM
Hellraiser
Hellraiser's Avatar
I soaked mine in wd40 then tapped em backwards n forwards with hammer till they freed off. It didn't take long, probably an hour with removing/refitting wheel , did have one once that I had to wail with the hammer a few times but it still freed off n I had no trouble with them again after. Simple enough job to do
Old 20-04-2016, 07:50 AM
Caddyshack
Caddyshack's Avatar
Thanks all
maxturbo
06-05-2016 06:43 AM
Fordmad!
11
20-04-2016 08:18 PM
Wardy ZS
19-04-2016 07:40 PM
uk-doctor
19-04-2016 02:14 PM
oilman
Trader Parts for Sale.
13-04-2016 09:30 AM
Quick Reply: 4x4 Rear Brake Calipers help needed
