quick question
Old 09-04-2016, 07:08 PM
cozzy jeff
cozzy jeff's Avatar
Default quick question
so driving the 150 miles home from norris motorsport today the coolant temperature was around 72 degrees,i think I have a 82 degree thermostat in the car am I right in saying mine wouldn't have opened?
do I need a lower rated one as I was getting very little heat through the air vents.
Old 10-04-2016, 08:07 AM
manuel boeckx
manuel boeckx's Avatar
I think Your thermostat was opening To soon. Normally the thermostat blocks the radiator below his temp reading. You can check the thermostat by feeling on the radiator hose, This should be cold below the thermostat reading. If you feel hot water At 60 degree It's already open then. Grtz
london_chris
14-04-2016 08:42 PM
RichieST
29
10-04-2016 04:38 PM
Indyrs
07-04-2016 09:53 PM
Simon78
06-04-2016 08:42 PM
xr2john
03-04-2016 08:05 PM
Quick Reply: quick question
