optimal running temperature
Old 27-03-2016, 06:22 PM
cozzy jeff
cozzy jeff's Avatar
Default optimal running temperature
what is the normal running temperature of the cosworth engine?
like what sort of temperature does the cold start shut off?
ive just replaced my fan switch,the switch came with the car,its an msd"uprated" switch but was bringing the fans in too late for my liking over 100 degrees on ecu monitor.
I replaced it with a 88/77degree switch which is turning the fans on at 81degrees and shutting them off at 75,is this causing the engine to run too cold?
im having problems with the car hard to start when hot so just guessing it still on cold start??
Old 27-03-2016, 06:24 PM
botters
competant bodger
botters's Avatar
most modern petrol cars only bring the fans on over 100 degrees not sure what it should be on the cossie though, i think they only come off cold start around 70 degrees
Old 27-03-2016, 06:25 PM
lacey
lacey's Avatar
If I remember right
I was always told you want to be running around 92 deg at the engine
Old 30-03-2016, 12:10 PM
Cossiemainful
Cossiemainful's Avatar
Optimal oil temp is about 90 deg.
Old 30-03-2016, 01:25 PM
Is your water temp sensor new.
Old 31-03-2016, 03:44 PM
cozzy jeff
cozzy jeff's Avatar
all my sensors are new Glenn, I've bought another fan switch but gonna speak to karl Norris in the morning to get advice to see if it's worth fitting.
SmudgerByName
18-02-2016 08:44 PM
fordsteve77
Escort MK 5 / MK 6
12-02-2016 07:51 PM
Sakis Gogos
12-02-2016 08:22 AM
Tommy777
10-02-2016 09:46 PM
KAnne
Ford KA
23-01-2016 03:33 PM
Quick Reply: optimal running temperature
