Additional water temp sensor. Where? Saph
Old 21-03-2016, 07:16 AM
jdsjojo
jdsjojo's Avatar
Default Additional water temp sensor. Where? Saph
Following a recent trackday I found the original ford one can give you a false reading as I lost coolant from the top rad hose after pre tightening jubilees before venturing out on track (must have just overtightened it). After pitting, sorting the leak and topping up coolant I went back out and had no probs.
I came back in and the car took 30 mins to cool down and for the fans to stop running. I then realised that I never bled the system (didn't think I'd lost much water) turns out I lost about 2 litres.
So I want to fit another temp gauge to give me the heads up that something isn't correct.
Where's the best place to retro fit an additional water temp sensor?
Old 21-03-2016, 09:49 AM
Moonstone Steve.
Moonstone Steve.'s Avatar
I have a boss welded on the thermostat housing with a capillary gauge in the dash
Old 21-03-2016, 10:24 AM
cozzy jeff
cozzy jeff's Avatar
I drilled and tapped the thermostat housing
900ss
18
29-01-2017 07:43 PM
benw456
08-03-2016 08:32 AM
cossie330
08-03-2016 07:51 AM
bassboy
26-02-2016 03:09 PM
Quick Reply: Additional water temp sensor. Where? Saph
