Group-A dump valve
Old 08-03-2016, 08:18 PM
turbotrev
turbotrev's Avatar
Default Group-A dump valve
I got hold of a second hand spec-r dump valve recently and have just tried it on my sapphire.
The car is fitted with a twin piston motorsport developements one at the mo but thought I'd try a diaphragm one to see if I prefered the noise.
When the spec-r one is fitted and the car is idling the dump valve leaks a tiny bit of air...
The diaphragm isn't split so I was thinking maybe the spring in it is not heavy duty enough??
Anyone running one of these?
Cheers Paul
Old 09-03-2016, 10:38 AM
3doorcozmess
3doorcozmess's Avatar
Is your vacuum gauge reading the same as b4
Old 09-03-2016, 08:40 PM
turbotrev
turbotrev's Avatar
I don't have a vaccine gauge fitted.
The leaking air is from the boost hose side not the vacuum side.
Idles fine, I think I just need to take it on th road and try it out....
Cheers Paul
Old 09-03-2016, 08:43 PM
botters
competant bodger
botters's Avatar
is it leaking from the valve itself or from where it goes into the boost pipe?
Old 10-03-2016, 10:26 AM
turbotrev
turbotrev's Avatar
The valve itself.
But only on idle it appears....
Once you Rev it up there's no air leak until you let off the throttle and it dumps its air (as normal)
Cheers Paul
gcfcos
11
10-03-2016 08:35 PM
xr4x4rs
07-03-2016 06:03 PM
lockie
07-03-2016 05:02 PM
3doorcozmess
07-03-2016 01:44 PM
Quick Reply: Group-A dump valve
