air filter size / types
hi im wondering what sort of size cone filters are necessary for a car running 350-400bhp its for a mk2 escort im building with a cosworth engine, im making an airbox to house a cone filter under the inner wing so space may be limited, im looking for minimum and optimal sizings so i have an idea of what i can get to fit my needs
thanks in advance
thanks in advance
I use a small ITG cone filter on my cortina t34 390bhp, i sometimes run with out the filter and can not feel or see any diffrence if its on or off so from that i assume its big enugh.
botters (02-03-2016)
botters (05-03-2016)
Received 1,042 Likes
Thanks matey. Its about 8 cm.s wide and about 12 cm long. Thats from the start of the filter to the end of the trumpet in the boost pipe.
I had to cut the boost pipe down for the fiter to fit.
http://www.demon-tweeks.co.uk/motors...gen-air-filter
Mines under the wing on my mk2 escort , it's under the wing out of the hot air of the engine , it's a foam pipercross from burtons ,got shield so no dirt gets to it works well
I used the conical option I attached mine to the turbo with a short straight silicon connector it doesn't stick out any further forward than the cam pulleys, I will take a picture for you tomorrow.
SmudgerByName
10-01-2016 03:14 PM
