coilover helper springs
It's best to get ones that compliment the spring rate already used. They are there to stop dislocation but if they are too soft they won't react fast enough to fill the void. Match them correctly is the best option, that way they will fill the void when needed and "help" the main spring. Dual rate springs in effect.
Ade (27-02-2016)
Whatever you choose to do make sure you reset your geometry. A 20lb 50mm helper will fully compress to about 13mm a 100mm 70 lb will be about 45mm or more from memory.
Depends in what context we are talking. Basically helpers help fill the droop gap and assister springs help the main rate spring. The problem with fitting the softest helpers is that a main rate spring has a mass. If the helper is too weak it cannot react fast enough to fill the droop void, so dislocation still occurs. Too heavy and it won't compress. Best thing to do is measure the droop gap then return damper to manufacturer and have an internal droop stop fitted
Mark V8
16
25-02-2016 04:04 PM
