fuel rail
Old 14-02-2016, 09:02 PM
MARKYMARKONE
MARKYMARKONE's Avatar
Default fuel rail
Hi
How do you disconnect the plastic fuel pipe from the fuel rail on a 2wd cosworth?
Mark
Old 14-02-2016, 09:06 PM
bdinnerv
bdinnerv's Avatar
Ford make a special tool to remove it but I think you can also use an air con tool - http://www.ebay.com.au/itm/VS0454-SE...ed6&rmvSB=true
Old 15-02-2016, 05:01 PM
bigdel
bigdel's Avatar
I used one of these to remove mine - http://www.ebay.co.uk/itm/7-in-1-Aut...4AAOSwWTRWwfbJ
Old 15-02-2016, 05:16 PM
pectelboy
pectelboy's Avatar
Save yourself a tenner , cut a plastic cable tie push it in on the rear of the spring thing a presto it's off , done it loads of times
Old 15-02-2016, 08:11 PM
MARKYMARKONE
Cheers guys, will give the cable tie ago, if no joy will buy a kit
Mark
Old 15-02-2016, 09:05 PM
tosh
tosh's Avatar
Have used a 15mm olive from a compression fitting before, just split it wrap it round the tube and slide it into the spring to release the fitting, have also used a short piece of plastic pipe of similar diameter, split it and chamfer the edge push it over the pipe and push towards the spring to release, if all that makes sense!!
MalZon
21
20-02-2016 10:45 AM
dickdastardley
15-02-2016 11:27 AM
Rodge.
11-02-2016 04:14 PM
Romain 83
10-02-2016 09:26 AM
fuzzy
07-02-2016 09:36 PM
Quick Reply: fuel rail
