Rear view mirror size
My 1990 4x4 Cosworth has a mirror that is approx 200mm across the widest point and has a dip function lever that you actually turn to the left or right. I have attached a picture but it is a bit hard to see. I just received a mirror off a Ghia which is approx 225mm across and the dip lever just toggles forward and back. (other picture) Can someone confirm which type should be on my car as I have always felt the mirror is too small as I can not adjust it so I can see the whole rear window at one time. Thanks David
Thanks Steve. I wonder what mine is off then. It has been in the car for at least the last 16 years that I have owned it. As I said it has always seemed a bit small to me. David
dal3door
15
24-04-2022 07:31 PM
Bazars
27
17-07-2016 12:56 PM
