Chip ID help
Old 03-01-2016, 03:21 PM
5hane
5hane's Avatar
Default Chip ID help
Apologies for posting up this sort of thread, but i cant figure out who made this chip in my car. The car is running greens / 3 bar sensor etc. It is currently running a t3 turbo but only to 14psi which seems very low; ive been told it was fitted with a t34 at some point (which i own but needs a rebuild)
Plugs after a good thrash seem a little sooted up, so its defiantly running a little rich - just would be nice to up the boost a bit but would rather know if i should swap the chip first!
apologies its a bit blurry
many thanks !
Old 03-01-2016, 09:50 PM
costina
Live long and prosper!!
costina's Avatar
Get your T34 rebuilt then give msd a call and they will be able to spec a chip to suit all of your mods.
Make sure that fuel pump and wiring are upgraded along with cooling fan wiring.
Msd will advise whats required.
Then you will be able to up the boost peak around 26psi holding 21psi
If your not confident doing it best to book it into msd.
Do it right do it once.
Paul
Old 06-01-2016, 07:19 PM
5hane
5hane's Avatar
Bought another L8 with a closed loop MSD chip for t3/greens so this should hopefully do the trick.
Old 07-01-2016, 07:18 PM
costina
costina's Avatar
Make sure the chip is correct for the spec if its for a std T3 then use a std T3 turbo.
you will not be able to fit a T34 without a remap.
If you can afford a quality .wideband afr gauge now is the time.
Old 07-01-2016, 11:14 PM
5hane
5hane's Avatar
Yep Im pretty sure its a t3, as i have the old t34 that was fitted to the car. Ive just started university so money isnt really floating about so im going to keep it the spec it is at the moment (should be 320ish i believe with the chip) and try enjoy some track days when i get the chance. - In a few years ill throw money at it with a new turbo etc, figured this would be a nice "temporary fix" to the current setup; and will hopefully reduce the current coughing and spluttering that happens if i hold the car at part throttle (which didn't help sound testing!) and will allow me to up the boost 21/19 psi i believe
Fortunately i managed to get a innovate lc1 wideband gauge last year for peanuts with two controllers so i will get that fitted properly - made a gauge mount just need to wire it up ! not sure if its the best in the world but its not a ebay special !
For the new MSD chip is there any code i can check to make sure it is what its suppose to be ( im sure it will be id just like to double check) - also will it run without the lambda plugged in ? (im presuming/ hoping it will just run in the "open loop" mode? ) - ill be going to the workshop when i get the chance to plug it in and see if its all okay, but wont be able to wire the lambda up straight away.
Setup should work well and be a night and day to the 14psi going through it at the moment !
Old 08-01-2016, 09:38 AM
costina
costina's Avatar
yes there is a code just give them a ring.
I use innovate stuff.
5hane (08-01-2016)
Old 08-01-2016, 09:53 AM
Blades Rally Team
Blades Rally Team's Avatar
Default MiniPro Chip Reader and TunerPro
Why not buy a MiniPro Chip reader and get yourself TunerPro see there site at www.TunerPro.net then you can at least investigate what you have in the chip as long as it's not encrypted if you need a xdf file I can provide one send me a pm
Don't go paying out loads of money until you know what you have got already
This is the EEprom reader you will need New USB TL866CS Universal EPROM FLASH AVR GAL PIC Programmer TL866 Pic
natehall (08-01-2016)
Old 09-01-2016, 08:00 AM
Guinnless
Guinnless's Avatar
All the OP needs to do is ring/email Stu @ MSD to see if the chip he's got is suitable for his setup. This is about as cheap as it gets!
Your Tuner Pro website doesn't mention support for Weber IAW ?
Old 09-01-2016, 10:08 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
All Motorsport Developments evolution weber chips are encrypted
Old 09-01-2016, 10:23 AM
Guinnless
Guinnless's Avatar
Thought that was the case, Tony.
And if it's not right he can order a new chip off MSD that does the job properly. I wouldn't be messing around with unknown maps and DIY!
Old 09-01-2016, 01:18 PM
Blades Rally Team
Default TunerPro Web Site?
Doesn't need to talk about support for IAW when you can pull the Eeprom (or any Eeprom from any ECU) and read it then have the XFD file to be able to change and re-burn the map onto a new Eeprom or the original as may times as you like
That's what I call cheap mapping!
Old 09-01-2016, 01:25 PM
Blades Rally Team
Default MSD
Sorry didn't realise this was an advertising site for MSD thought it was to help and develop people's knowledge of the Ford product and a forum for other to advise how to develop their own and others cars with assistance from a few people that may know a little more for FREE not chargeable.
If NOT let me know and I will bail out!!!!!!
Old 09-01-2016, 02:33 PM
Turbosystems
Super Moderator
My post was in response to the highlighted text you wrote
Old 09-01-2016, 03:07 PM
Guinnless
Guinnless's Avatar
That's what I call copyright theft unless it's your "mapping" of course.
By all means map your own car of you wish/can but I wouldn't want a map from a "bloke off a forum" without an appropriate repuation.
The OP had bought an ECU with an MSD chip so I thought it sensible to suggest he contact MSD to verify the spec, if the chip was from Turbosystems then contact Tony. You wouldn't approach Vauxhall with a question about a Ford would you?
Why don't you live map it for the OP, for free of course.
Old 10-01-2016, 03:59 PM
Blades Rally Team
Default Copy Right Law
Seems you don't understand Copy right law then it is only against the law to re-sell the map not to investigate what you have brought with the car the rights of that map transfer with the sale!!!!!
All I am trying to do is get other like minded people to understand the principal of mapping so that they have an appreciation of the system they do not have to have a go them selves I would always suggest having an expert map the car but if you have this equipment and an emulator (like an Ostrich 2) then the guy on the dyno can use there equipment to live map the car not use someones compromise map (MSD or other) that is not specific to their particular engine
Will help anyone to understand the principals but would always advise them to use an expert on a dyno to live map any car as they are all different and a propriety unit will always be a compromise(Unless you know better!!)
Old 10-01-2016, 05:12 PM
5hane
5hane's Avatar
Thanks for everyone's input, I hope to recoup some of the costs of the new ecu and chip, but may keep the old chip for future use - I would be interested to see what it has been set up for, and also it would give me a spare chip that i can modify rather than having to source another! This is defiantly something i would like to have a go at in the future, just at the moment i want to get the car running nice with its current spec and get to a few track days. Also want to make a new loom for the car using some COP coilpacks ive got back home (figured this is a project i can do away from the workshop when i need a car fix! - and more productive than fooking netflix )
Im away from home till next weekend so wont be able to try the new ECU till then, and the fella who i share my lockup with has took his r32 apart in front of the garage door so there wont be any testing for a while, but as long as it all runs and gets up to temperature I think i can presume that there is nothing wrong with the ECU or chip ive bought?
Old 16-01-2016, 05:25 PM
5hane
5hane's Avatar
Right i managed to get the new ECU plugged in the car - with no lambda plugged in and it all seemed to run okay so i think it is all okay - i cant get the car out of the garage to properly test if for a while.
So im going to message MSD and see if they can id the new chip,
Also, im sure my old ecu is a L8 - but it has the L1/L6 case? can anyone confirm this from a picture? (white adjuster) - I think i would rather swap the ECU case so i can use the mountings.
Cheers for the help !
Old 16-01-2016, 07:09 PM
I would defo get the fueling checked when its up and running.
Old 17-01-2016, 08:27 AM
Guinnless
Guinnless's Avatar
It's probably been swapped into a L1/L6 case so that it will fit properly into a 2WD mount behind the dash.
L8s on 4WDs fit behind the passenger kick panel IIRC.
Old 18-01-2016, 08:15 AM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Here is the data you require.
Calibration Specification for 8123:
Originally Sold: Feb 2015
ECU Type: L8 ECU
Babyboard Required: Yes
Pectel or Weber: Weber.
Encryption Key required: No
Engine Type: Ford YB 2.0
Engine Compression: Standard
Head Spec: Standard
Camshaft Spec: Standard:
Injectors: Bosch 803s
Turbocharger: T3.48
Map Sensor: 3 bar
Intercooler: RS500 type
Additional Features Installed:
Closed Loop active: Yes
Air Injectors active: No.
Serial Data active: Yes.
Anti Lag active: No
Launch Control active: No
Flat Shift active: No
The following 2 users liked this post by Stu @ M Developments:
5hane (19-01-2016), blakozar (21-11-2016)
Old 19-01-2016, 08:43 PM
5hane
5hane's Avatar
Awesome thank you for that ! should be perfect for my current spec then.
Last questions i have, i think,
What distance should the lambda be from the turbo? My wideband gauge lambda is about 10 inches from the turbo, will this be in a similar position ? OEM its usually well down the exhaust, but i have seen them directly behind the turbo (Which i imagine would get too hot?)
Also boost wise it should be setup on the chip now and not need to be adjusted? (21 peak psi? dropping to 19psi?) - sorry i could answer this by running the car but im away from home now for a few weeks unfortunately !
Thanks for all inputs on the thread!!
Old 21-01-2016, 07:40 PM
AiToR51
AiToR51's Avatar
If you are using now a wideband lambda it usually has a narrow band lambda output (0-1V).. In that case you don't have to install a new lambda..
I'm using an MSD chip with this setup and is working very well
Old 21-01-2016, 08:52 PM
costina
costina's Avatar
This is correct. Most afr gauges have this innovate being one of them.
I do run 2 lambda sensors 1.wide and one narrow for closed loop. 1 about 4 in away from exhaust flange and other 2in behind that.
Old 21-01-2016, 08:54 PM
costina
costina's Avatar
Old 21-11-2016, 06:23 PM
blakozar
blakozar's Avatar
ECU Type: L8 ECU
Head Spec: Standard
Turbocharger: T3.48
Map Sensor: 3 bar
Anti Lag active: No
I need calibration specification for 8185
turbotrev
261
25-02-2019 09:12 AM
Benzy50
16-12-2015 12:13 PM
Adam-M
13-12-2015 05:33 PM
paceo
10-12-2015 09:33 AM
Quick Reply: Chip ID help
