2wd water temp gauge not working
Hi all
I changed the oil pump due to the pressure dropping all is good with that but now but the coolant temp gauge has died during this! The sensors good I know that but there's no power to it. On the wiring diagram it shows it's a direct feed from the instrument cluster and I'm guessing that's where it gets it live from to?
Cheers all JC
Cheers all JC
Cant be the earth as its earthed through the head and there's a soil Earth on that. I shorted out the wire to earth and the gauge didn't move at all to. Yup all checked done with ignition on.
I re ran the wire round the front by the intercooler before the engine was lifted but it's a possibility, trying to avoid chasing it through the loom but I think that's the only other option now.
ah ok I get you. yes connectors all clean have spliced a replaced a small section as someone had bodged it. Do you think it could be the gauge?
Cheers for the help chaps. Traced it back today and the cable had a break in it past the injectors in the plastic conduit. All working now
jc1989rs (23-12-2015)
Adam-M
13-12-2015 07:31 PM
