Castor angle
Castor angle
afternoon people
I'm after some advice,i fitted 4x4 hubs to my 3dr si I can fit new gas gold and some ap brakes.
But now my castor angle is way out
Do I have to fit 4x4 arb to bring castor angle back ??
Any help would be grateful
Thanks mark
Thanks mark
Are the 4x4 hubs the only part from the 4x4 that you used? And which way is the castor angle out, too high or too low?
The 4x4's have different geometry hubs, arb and crossmember. So I wouldn't advise to mix and match any 2wd and 4x4 parts. Although with only the 4x4 hubs I thought it might have been OK, but apparently not.
Hi Marc , I've the 4x4 hubs , changed also half the adjustable bottom arms to pinch bolt type to match hubs.still using 3dr arb
Castor angle of wheel is forward
Now to get 3degree of camber I've nearly would out whole of steering rod/track rod from track rod end
What is the minimum amount of thread that could be safely left in track rod end
Thanks mark
Thanks mark
Sorry to confuse you Marc
Yes I have a little to much forward castor but I think it's ok
Do you think -3degrees of camber is to much
Mark
Mark
If you want to run 3 degrees of camber on track but the track rod ends are not long enough you can use track rod ends from a Granada mk3, which are the same fitment but about 1.2 cm longer than the Sierra ones. As far as I'm aware the Granada mk3 track rod ends are also the same as the Sierra XR4x4 ones (also wider track).
Too much castor would only be a problem if the tyres touch the bumper. Not enough castor is indeed a problem.
Ok next question , when I raise and lower car from floor with jack as wheels hit floor it's as if the weight on arb is changing toe angle on wheels
Mark
Mark
Hi Marco spoke with some helpful chap at scs and he told me I need to change to the 4x4 arb
So I gonna give that a go see how I get on hopefully sorts problem
Mark
Mark
the front wheels even further forward and I tried getting mk3 granada track rod ends and there the same as Sierra so I've ordered tie rods 20 mm longer and gonna refit the 2wd arb
What a f........ Mission
All in a panic as I've a trackday next weekend
Mark
The front suspension is so hard (500lb springs) that there's not gonna be hardly any suspension travel and it's only for track use so I think I be ok with bump steer there's only 1 way to find out
Mark
Mark
rog
14
04-07-2016 03:28 PM
4x4RSMike
13
03-12-2015 05:43 PM
eddyj
17-11-2015 04:27 PM
