Plates for blanking off ABS sensors on a cossie hub?
I want to run my saph without ABS and would prefer to do it neatly by properly blanking off the holes in the front and rear hubs, is there anyone that has done this or a place which provides something I can use.
I'd rather not use a rubber grommet if i can avoid it, I was thinking more along the lines of some silicone sealant and then a small plate on top of with a bolt which screws into the original thread to stop shit getting into the hole.
Something I have been thinking of too, it might be best to cut some plate and put that over but I have toyed with just using the sensors and cut off the wires .
Glad to hear it, there must be a few people that want to do this as well. I'm sure if someone made these small plates that there would be a market for it.
I did think of using sensors too, but i don't have any old ones to use and i think it would look better finished with a fabricated plug of sorts.
Just made small plates and bolted using original hole on mine,then painted the whole thing black, reason being is that if you have a picky mot inspector he could notice that the car originally had abs fitted and fail the car as it no longer works, for this reason I didn't use my old sensors.
Try contacting anembo engineering I dare they wouldn't mind making up a few sets and anodising them.
can I ask if you do this mod ,Then do you get rid of the abs pump / master cylinder unit on the bulk head and if so what master cylinder and servo do you use ?
4x4RSMike
13
03-12-2015 05:43 PM
