Front Hubs... 4x4 Sapph vs Escos
The hubs are different were the brake mounting is i had some sapp ones done(front bells and brkts for my brembos) by martin hadland and while they were being done i refurbed my esc hubs and bearing when fitting the kit when it arrived i found the offset for the brake mounts to be different
You sure it wasnt xr4x4 you had?
They have the brake mount offest differant
But my calipers fitted straight onto the saph hubs
1st to 200 without NOS
BRAM (17-11-2015)
Resident Wrestling Legend
if you don't have the eye for the detail, at lets be honest, other than those people who live cosworth, you would be hard pressed as an average punter to know the difference if you didn't have the item you needed in your hand to compare against
i made that mistake a few times and eventually i discovered that there was, from memory, 8mm difference between the 2wd and 4wd version, with the v6 xr hubs coming in at 4mm in the middle and the dohc hubs having a 1.5mm difference compared to the normal 2wd offset
this was 15 years ago so my numbers might be out a bit
I had both xr & cos hubs a few years ago, and they did indeed need to be side by side to tell the difference. Easy to see when the brake disc is on of course, but bugger all difference to the naked eye otherwise D:
he's said the offsets were different, which would most likely mean that he's been sold a set of xr hubs masquerading as cossie items
fatboy billy
04-11-2015 08:05 PM
