Ford Scorpio Diferential Doubts
Hi,
I have a doubt related to a Ford Scorpio Differential with the following reference:
85BB AA 362
4A 9E 08.
Is It a LSD diferential?
Best Regards,
José Novo
85BB AA 362
4A 9E 08.
Best Regards,
José Novo
Only way to know for certain is try to rotate the rear tyres/flanges. If they rotate in opposite directions, no LSD. If there is a working LSD inside, they should rotate in the same direction, and resist noticeably if you try to rotate one without the other.
I thought the AA codes where LSDs, and seeing that the ratio is 3.62 could mean it's a 7" diff from a Scorpio 4x4 (Granada mk3 in UK). But to be sure just turn the drive flanges in opposite direction and see if there's a lot resistance. If yes, then it's an LSD. If no, it's not an LSD, or the LSD is worn out.
MARCOSWORTH
18
16-11-2015 07:03 PM
james kiely
16-11-2015 10:52 AM
JordanSpencer
28-10-2015 11:56 AM
