Brake problems
Brake problems
Hi I recently rebuilt my brake system bleeding from a dry setup followed the workshop manual instructions the left caliper has acceptable brake pressure but on the right caliper I can't even get any fluid to it under pressure the pedal is rock hard , I removed the line from the master cylinder and pumped got not the best result can this unit be rebuilt its on a 2wd sapphire cosworth
I think the abs block does have a return to the master cylinder, it is the larger centre outlet on the master on a 4x4 and car.
Resident Wrestling Legend
we are basing our assumptions on the later abs setups, which have a separate master cylinder setup and a separate abs valve block
in which the master has one feed to the block for the rear line, one feed to the block for the front line and another return back from the block
the block then has 2 inputs and 4 outputs, one return to master, one line to the rear and one for each front
one the early versions the block was integrated into the master assembly
if you have the later one then you should be seeing pressure from the master to the block and it will be the output that is the problem, sometimes these have been caused by something as simple as an air lock
JasonPD
22-10-2015 07:29 AM
Mark V8
16-10-2015 03:09 PM
