3 bar map sensor
3 bar map sensor
I've just bought a genuine weber 3 bar map sensor off fleabay. It says it has been tested and is in perfect working order. how can i check this for myself? I fitted it straight away and tested the car. And it is backfiring under load. Worse then the brands hatch 3 bar map sensor i had on before hand.
The code on the side of the sensor is SPA05/01 1769 if that means anything to anyone.
Does it actually have Marelli Autronica embossed on the front?
SPA don't sound Like Weber to me, can you post a photo up?
Chris 82 (07-11-2015)
andy130
25-10-2015 09:44 PM
