Saphire V8 conversion
Firstly hello. Ive browsed this forum many times and found it full of great information.
I have decided to sign up and hopefully get a little help with my Saphire.
Im from NZ and we are lucky here that rules around modified cars, although strict, allow you do build just about anything and make it road legal.
Its a 1990 Saphire sedan, automatic with 2 liter N/A DOHC.
Plan is to remove the engine and box and fit a carburettored 289 Ford V8 with a toyota 5 speed box.
Im very familier with doing engine conversions in Japanese cars so this ford will be a little bit of a challenge for me as its built very very different to what im used too.
A couple of questions that are pusseling me at present.
The auto gearbox has a speedo cable coming out of the right hand side and what looks to be VSS speed sensor of some sort coming out of the left hand side.
What is the VSS used for ? ABS ??
My Saph has a electronic brake booster, can this run independent of the abs system ? in other words can it be wired up with a relay etc etc to work without any other modules ???
I guess im worried my ABS system and Electronic booster will not work after i fit the new engine.
Im reasonable good with electronics but not used to working with, or has i ever worked with a car that has an electronic booster.
If all else fails i can always remove the whole abs and booster to fit the older style vacum booster and non abs.
opinions please.
Will post pictures of my build in the new few dys.
Thanks
opinions please.
Thanks
The speed sensor has nothing to do with the ABS system, all the signals for the ABS come from the wheels speed sensors.
There is a way of just using the ABS pressure pump without the ABS valve block - you may have to search the forum for a while to dig up an old post to find the details of how to do it.
Cheers. I didnt think the VSS in the gearbox would of been for the ABS but wasnt sure. Wonder what its used for.
Have done a fair bit of searching the net for info on the brake booster pump, but now im a member on here it may bring up more searches
21
14-09-2015 06:38 PM
Eigdoog
13-09-2015 05:46 AM
The Enigma
12-09-2015 10:12 PM
Si B
12-09-2015 06:49 AM
