Fuel gauge intermittently dropping off, then works OK again.
As above, the fuel gauge is intermittently dropping off, then works OK again.
I haven't dropped the tank yet but is this most likely a loose connection on top of the tank?
1st time it happened was going fairly quick over a bumpy potholey road (unusual in Ireland...NOT ) and it dropped to well well below empty. Then a few minutes later it came back up again.
I've also noticed that it only fills up to approx 95%, before it filled up higher basically.
Don't want to drop the tank unnecessarily as it'll take time and maybe it's not needed!
Also, another thread I just started has a problem in that the ABS light comes on when indicating right. Possibly related to the clocks or not...?
https://passionford.com/forum/ford-s...ing-right.html
Any help would be greatly appreciated.
Thanks.
Philip.
Thanks.
Philip.
Hi Phillip
I had a similar problem a few years back that turned out to be a bad connection in a wiring loom plug in the back of the boot between the tail lights from memory. I removed the plug / socket and soldered the wires and haven't had the problem since. David
Sierrasideways (17-10-2015)
Cossikev
13-09-2015 02:00 PM
