2wd front discs
Old 05-10-2015, 08:40 PM
studabear
studabear's Avatar
Default 2wd front discs
Ok guys what are the best sierra cosworth 2wd front brake discs to use these days, I don't have a cossie but my zetec turbo escort uses the 283mm discs. I've warped a set from the motor factors that I use, I've also had a set of drilled and grooved of ebay that were iirc around £70, these feel warped now (still need to confirm on the brake tester at work)
Is there a good brand to go for these days or is it pot luck? I give them a relatively hard time as the car is a toy that only gets used for pleasure driving.
Stu.
Old 06-10-2015, 08:44 PM
studabear
studabear's Avatar
Come on guys 146 views, does nobody with a 2wd cossie have the 283mm discs anymore or has nobody replaced them recently?
Old 06-10-2015, 08:50 PM
Sierrasideways
Sierrasideways's Avatar
http://shop.grahamgoode.com/front-br...77-62601-p.asp
studabear (06-10-2015)
Old 06-10-2015, 09:03 PM
Tim Wharton
Tim Wharton's Avatar
Ive bought Bosch ones recently from Matt Lewis seam good quality
Im doing the Grand Prix trackday at Brands on the 28th I'll let you know if they servive
Cheers Tim
Old 29-10-2015, 10:16 PM
Tim Wharton
I've done the Grand prix trackday unfortunatly the bosch discs didn't servive
Proberbly not rearly a fair test on them were working rearly well did a cooling down lap stoped for lunch went out again bad vibration came in cleaned disc serface still no good
I think I need bigger brakes and bigger wheels to fit them under better start saving
£3000?
I have used grooved ones from woodford Garage they lasted longer but were nearly twice the price and I was only doing the Indy circuit
Cheers Tim.
Old 26-11-2015, 04:16 PM
jay991
jay991's Avatar
I bought some from Mtec, can't complain about them... Only had normal road use out of them
Old 26-11-2015, 05:26 PM
costina
Live long and prosper!!
costina's Avatar
National grooved discs and ds2000 pads good combo and available from burton power or woodford.
Paul
Old 27-11-2015, 11:14 AM
R4N SS
R4N SS's Avatar
dont get the Tarox 40 grooved and drilled discs as i bought them and they didnt really last long and warped.
My £10 second hand genuine ford discs lasted longer and did more trackdays lol
Old 27-11-2015, 01:32 PM
Mad_Mat
New Owner
Mad_Mat's Avatar
Paul
I,ve been using these national grooved discs on my 3dr with ds2500.
Quite acceptable for road use but i,m not suprised they give up on track.
Old 27-11-2015, 04:42 PM
dojj
Resident Wrestling Legend
dojj's Avatar
the pads you use will also have an effect, the harder the pad the more they will wear the disc away which might be why they aren't lasting
have you tried cheap pads AND cheap discs?
or does anyone do a 2 peice version?
Old 01-12-2015, 05:11 PM
R4N SS
R4N SS's Avatar
I always used ds2500 pads on my cossie
3doorcozmess
15-09-2015 06:06 PM
28
08-09-2015 07:10 PM
3doorcozmess
07-09-2015 01:32 PM
rsstav
07-09-2015 04:43 AM
yorkie92
06-09-2015 05:34 PM
Quick Reply: 2wd front discs
