3dr cosworth starter motor
Old 24-09-2015, 07:54 PM
cossie362
cossie362's Avatar
Default 3dr cosworth starter motor
Evening peeps
What options are available to replace my
Starter motor solenoid gets stuck when car is warm
Had a look on ebay just want to know which
One is the best to use. ?
Old 24-09-2015, 08:55 PM
cossie09
cossie09's Avatar
Default Starter
Originally Posted by cossie362
Evening peeps
Hi.buy a 18td ford connect van one the starter fits the 2wd cosworth and is cheap to buy,hope this helps.
Old 07-10-2015, 08:28 PM
Tim Wharton
Tim Wharton's Avatar
The cossie starter is quite esey to strip and repair
If you have a workshop manual it should give you an exploded view its proberbly just gumed up with clutch dust
You could just check the terminals on the solenoid are all clean and tight too
Cheers Tim
Old 07-10-2015, 09:09 PM
james kiely
james kiely's Avatar
as said the transit connect one is the one to go for
Old 11-10-2015, 03:53 PM
cossie362
cossie362's Avatar
Does it matter what year on the connect starter
Motor?
JK12
33
26-04-2021 12:09 PM
3dr cossie
21
20-11-2015 05:00 PM
CLIVE
02-10-2015 12:58 PM
IAN RS2k
18-08-2015 07:51 PM
14-08-2015 07:29 AM
Quick Reply: 3dr cosworth starter motor
