Quickest road legal rwd Cosworth quarter mile?
Probably been mentioned before at some point but who and what time was the quickest rwd Cossie on the quarter mile?
Rwd only, on road tyres, with no nos...
Anyone??
Cheers Paul
Anyone??
Cheers Paul
That is quite a specific set of requirements, I would expect that people looking to set "quickest" to a point where it is almost advertised is going to start putting sticky rubber or nos on there.
I don't have a clue but would be interested to know how quick and how they compare to other cars.
I wonder if Rod has that time as he had road legal tyres, only thing is that he had Nos so would need to know his without that.
cossie fan (unluckerly)
I'm more impressed by what speed it's doing at the end of the quarter mile. Shows more realistically how quick the thing will be on the road on the move
turbotrev (24-09-2015)
Happily retired
Mine has never actually done a quarter but have taken a time during 0-200mph run on datron. With 640bhp off gas as that is only switched on at higher speeds would have been road tyres & pump. 11.5 @ 138mph. Geared for 217mph & on a runway its a shit time & others will have gone quicker this was back in 2004.
At totb1 in 2002 with about 480bhp we ran 13.2 @ 129mph over 500metres. Im told by the drag boys to achieved that must have hit the quarter in 11.8 secs or quicker that's fast for the Power im told. Sorry im not a drag boy my car would need drastic changes to be that.
Hers a vid of that run in 2002. Mark is driving im the Owner & the commentator has his knickers in a twist but watch the end for a very young Mark Shead looking like a young Cherub .
Cool, thanks for the info Rod. Mark must have turned up on his skateboard as he was too young to have a licence!
So it is likely that a car geared for the quarter on a sticky surface like pod and set up for a launch would greatly improve on that plus we now have more modern road tyres, much better ecus and the twin scroll turbos.
Plus the car can now run much better compression ratios. Back then did you have an intercooler of any decent quality as I bet there would have been heat soak on an RS 500 style.
Lee cattermell ( spelling). He was cracking up the 1/4 mile, if he had all your requirements I don't know but he put in very good times, Rod may know more on this but he was always there or there abouts.
Mark
Happily retired
Lee did have Nitrous but this was a fast car his 0-60 remains unbeaten for a RWD. The 0-100 in 7.3 compares well with mine at 6.9 but from then on its simply no contest. Lee could get them off the line better than anyone else. He was called 'twinkle toes' back in the day.
Happily retired
He's on one of the Fast Ford or Performance Ford DVD's. The one with Euan begbie (spelling) saph and the clunky box but fast RS200.
Lee was very quick, maybe the quickest, but he had nos....
Is nos cheating??
A lot of people seem to take the approach that if you have nos it's just bolt on easy power and cheating
Cheers Paul
Is nos cheating??
Cheers Paul
So apart from Lee and Rod anyone else ever or now hitting 11's or low 12's in road legal form?
Cheers Paul
Cheers Paul
My opinion is use anything you can to get the job done, bolting on a bigger turbo is bolt on power too. I appreciate that a 150 shot of nos wouldn't last long on the road but surely nos is best used to get on boost and torque fill / overcome gearing rather than the long open throttle (wot)?
What's your plans then trev ? You building a contender? Tibs was quick thiers I guy I know in Greece that's hitting 10.8 with 650 bhp seq box and that's 4x4 with animal launching
I don't really have a plan as such.
Just wondered what the quickest cars were/are in that kind of spec.
I've had a few runs on the quarter but I can't get good traction off the line when launching hard.
My times are crap but it'll pull a 123 terminal.
I have around 500hp, big tooth box, supra diff at present but def need to start looking at a good suspension setup, tyres and beam combo next.
I'm not after an outright drag car/setup and I know Sierra's are def not great for drag racing too.
Cheers Paul
Cheers Paul
I can see your time improving with those mods let us know how it does when you go down respecced
I would love to see it re timed with nothing other than a 6degree beam on there properly set up to see the difference and then change bit by bit to see what does what.
turbotrev (27-09-2015)
i would too mate! That would be interesting.
I am saving for a beam so hopefully early next year I'll have the funds for one.
For now I'm interested in just trying a few other simpler cheaper options.
The reasons for doing this are 1: to give me time to save for a beam and 2: Lee Cattermoles old sierra's were probably the quickest accelerating cosssies ever and he had a standard rear beam in both his cars.....
Cheers Paul
Cheers Paul
With enough money, a good set up and modern advancements it should be possible to better those times or at least get close with lower spec.
My 205 gti 1.9 had a reputation back in the day for lift off oversteer making them go ditch finding backwards....my old one use to love getting the back end out.....now with modern tyres you cannot unstick it on the road, even in the wet. I am sure you could on a wet track but it just goes to show rubber tech from early 90's to now has moved on so far.
That was Danny B who used to work for Adrenaline race and performance.
His car ran good times because of its drag suspension setup and that it wasn't crazy power.
Cheers Paul
Cheers Paul
My mate got a 2wd saph just into the 11's that was a t34/greens car cost a him a diff to do it though, he also had a converted mk4 escort 4x4 on a t38 that made low 11's.
Not many cossys run the 1/4 mile was really disappointing at Forfest I only saw 2 or 3 running,
I honestly don't know, a friend of mine has a mate with a similar spec mk1 golf in the lay 10s but I really don't know. If I can get the transmission to be strong enough then 100bhp more should be simple ( if expensive) so maybe 12 to 10 sec car somewhere.
Yes it starts to get expensive after 500 bhp lol
To be fair, getting as close as I am to 500 and doing it properly hasn't been a cheap experience and my engine hasn't been apart yet!
Toby I will have a spare 200 engine at some point next year keep in mind
Caddyshack (28-09-2015)
This is road legal in Malta, but you can see its running drag tyres here
Cost him a diff in the end and had to give it death 7k launches to do it, there's a blue mk2 escort that runs at most of the ford events at pod he just got in to the high 11's at fordfest, my Cortina ran a 12.5 on a t34 .48 but hopping to run a high 11 with a gear ratio change.
Any vids or slips of this saff that ran an 11 on the t34?
You hardly see any running 11's let alone a car running a t34!!
Cheers Paul
Cheers Paul
Fastest 1/4 mile fir street legal Sierra Cosworth
Hi, I am new here.
We managed to run 10.5@136mph with a fully street legal Sierra Rs500 on street legal tyres and 10.2@137mph on slicks.
You can find the videos on youtube
That's crazy!
Thought there would be a little more of a time difference when running the slicks?
What's the rough engine spec and power?
I've seen your vids on YouTube, good stuff!
Cheers Paul
Cheers Paul
borboyous
22-08-2015 11:17 AM
