Reverse lights come on when braking?
Old 12-09-2015, 06:01 PM
The Enigma
The Enigma's Avatar
Default Reverse lights come on when braking?
When driving back last week someone pulled up next to me and said when I was braking the reverse lights were coming on? James said it would be the earthing point for the rear lights but I don't know where it is? I've looked in the boot and the wires seem to go through the back of the boot and then under the plastic cover by the back doors, but there isn't any earthing points that I can see? When indicating the brake lights do slightly light up as well. I don't know if it related but the rear fog lights don't come on when I press the rear fog light switch. I'm guessing they are the lights closest to the number plate?
I've tried cleaning the connectors for the rear lights and no difference.
When the drivers side indicator is on, the indicator and brake light illuminate completely and the other 2 light up slightly, the passengers side lights light up slightly as well.
When the passenger side indicator is on the indicator light illuminates completely and all the other lights come on slightly.
When the brake is pressed only the reverse lights come on, not the brake lights.
Old 12-09-2015, 08:25 PM
jsa
jsa's Avatar
James is right, classic poor earth symptoms. Look at the light cluster, the bulbs will have wire with different combinations of a solid colour and stripe colour. As well there will be a wire common to most bulbs, likely to be a solid colour such as brown, this will be the earth wire. Alternatively the common side of most bulbs will connect to earth through the light cluster mounting, look for a metal connection between the bulbs and Mounting points.
The Enigma (12-09-2015)
Old 12-09-2015, 10:12 PM
The Enigma
The Enigma's Avatar
Sorted. The connectors were on upside down..
yatta
21-05-2016 10:31 PM
S3an
13
13-09-2015 10:01 AM
morg65
Escort MK 5 / MK 6
17
11-09-2015 08:40 PM
gingeRS
04-09-2015 06:29 PM
hopper350
04-09-2015 12:53 AM
Quick Reply: Reverse lights come on when braking?
