Axle tramp???
Old 26-08-2015, 10:12 PM
gabbo
gabbo's Avatar
Default Axle tramp???
Hi all, ive got a 2WD sapphire and when i spin the wheels its like the back end is jumping/juddering which i assume its axle tramp? Am i right with this?
If so what could be causing it and how could i cure it?
I had toyo proxies t1r's on for the past couple of year and just put fresh bridgestone adrenalin's on and its done the same with both tyres.
Thanks
Old 27-08-2015, 10:50 AM
Guinnless
Guinnless's Avatar
Check all the bushings on the beam and the trailing arms.
The beam has three mounting points, two at the front and the single mount point where the diff hangs from.
Make sure nobody has put poly bushes in the trailing arms.
Old 27-08-2015, 07:16 PM
gabbo
gabbo's Avatar
Yeah its been fully poly bushed before i bought it but there that flo-flex orange ones, already had to replace some on front end as they were worn.
Why do you say about that could they be fitted incorrectly or something?
I did check all bolts and mounting points for bein tight and all seems to be fine.
Thanks
Old 27-08-2015, 07:59 PM
jamie's
jamie's's Avatar
The trailing arms shouldnt have poly bushes fitted realy,
Its a bearing thats in them originaly so bushes dont work right in them
Old 28-08-2015, 09:02 AM
Guinnless
Guinnless's Avatar
So the crappy Flo-Flex arm bushes are quite possibly your problem. Poly bushes in the arms are a serious downgrade
The arm bushes are supposed to be sperical bearings and it's going to cost a a fair bit to put things right.
Old 28-08-2015, 03:56 PM
R4N SS
R4N SS's Avatar
check your wheels and tyres arent bent too
Chas
21-09-2015 08:57 PM
Vacuman
16
03-09-2015 06:26 AM
atm
01-09-2015 04:56 PM
TrevCos
22-08-2015 06:05 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Axle tramp???
