Map sensor question
Old 22-08-2015, 01:27 PM
Anutternutter
Anutternutter's Avatar
Default Map sensor question
A quick question for you clever folks. My standard map sensor has died on my 1990 4x4 saff cosworth. It's running a stage one tune. Can I use a 3 bar map sensor to replace it or does it have to be another 2 bar item? Cheers!
Old 22-08-2015, 01:56 PM
martysmartie
martysmartie's Avatar
No, it must be 2, as the scales are different.
Martin
Old 22-08-2015, 06:44 PM
Anutternutter
Thanks for the reply Martin. I'm glad I checked! Cheers again, Matty
Old 22-08-2015, 08:00 PM
costina
Live long and prosper!!
costina's Avatar
Do not use the aftermarket ones from brands hatch etc.
WHY
I had a long conversation with a chap at webcon he informed me that they tested those and would not sell them due to poor quality. And weber marrelli will not be making anymore and have scraped the tooling.😕
So unless the likes of Stu at MSD can come up with a bosch replacement and can map to suit we are all fooked and will have to go aftermarket.
Paul
Old 22-08-2015, 08:38 PM
Anutternutter
Bugger, I've just ordered an aftermarket one. Fingers crossed eh? 😳
Old 23-08-2015, 06:57 PM
Adam-M
Adam-M's Avatar
From brands hatch performance? I've read lots of bad reviews unfortunately
Old 23-08-2015, 08:22 PM
Anutternutter
The one I've bought came from an ebay seller called motorpartsworld. It says it's a direct replacement. For £25 odd it's worth a punt but I'm not totally convinced. I'll report back with a verdict as soon as it's arrived and I've fitted it.
Old 23-08-2015, 08:30 PM
turbotrev
turbotrev's Avatar
I went to a 5 bar sensor and are relatively cheap in comparison to the 3 bar ones, but your car will need remapping
Cheers Paul
Old 23-08-2015, 09:17 PM
Anutternutter
I'm hoping to avoid a remapping situation if at all possible. If this one doesn't work I'll look out for a second hand original one I reckon. Cheers, Matty.
Old 23-08-2015, 09:54 PM
lacey
lacey's Avatar
Cheers Paul
Where did you get the 5 bar one from mate ?
Old 23-08-2015, 10:16 PM
martysmartie
You cannot tell, just because it runs means nothing, the only way to tell is to compare the scales.
Martin
Old 24-08-2015, 12:10 AM
turbotrev
turbotrev's Avatar
NMS supplied and fitted it mate as I had a load of work done as well as some mapping
Cheers Paul
lacey (29-08-2015)
Old 24-08-2015, 06:25 PM
Anutternutter
Cheers for the info Martysmartie. Must admit though, running at all would be an improvement on my current situation 😂.
Old 24-08-2015, 08:01 PM
costina
costina's Avatar
Martin is correct only way i would run a aftermarket sensor would be with a wideband afr gauge but its still a lottery.
Can u afford a 2k rebuild on your engine if it fouls up?
Old 24-08-2015, 09:09 PM
Anutternutter
Unhappy
What would you folks suggest is my best option? I can't find a new genuine one, a second hand genuine one is a gamble as it may be duff and aftermarket items are a gamble too.
Old 25-08-2015, 05:26 PM
Jan300
Jan300's Avatar
I using 3bar map sensor from Brand Hatch and its working good.The scaling is good and I also check with wideband lamda meter.Other copies you find in internetshops is normaly shit.
Old 25-08-2015, 06:05 PM
Anutternutter
So, mixed reviews on the brands hatch sensors. Good to hear yours checks out Jan300. What's the best way to check the scale on the sensor? I'd like to check the one I've ordered when it arrives. Better safe than sorry. Cheers 👍
Old 25-08-2015, 08:12 PM
Guinnless
Guinnless's Avatar
So you have tested the others?
Old 26-08-2015, 06:44 PM
Jan300
Jan300's Avatar
Yes I have tested several.
Old 27-08-2015, 06:03 PM
costina
costina's Avatar
Cheers Paul
got any pics please mate?
Old 28-08-2015, 10:19 PM
KW-rscos
KW-rscos's Avatar
You can buy my 2bar map sensor, came off my 89 2wd all working fine, only selling as gone to stage 3...
Old 29-08-2015, 03:50 PM
Anutternutter
How much do you want for it buddy? To check, it is the same as a '90 4x4 cos (APS02/03)? I believe it is. Cheers
Old 30-08-2015, 06:13 AM
KW-rscos
KW-rscos's Avatar
£25 posted? Yes the number is the same, Thinking about it at my storage unit I have a 4x4 2bar from my 92 4x4 saph!
Old 30-08-2015, 07:48 AM
Anutternutter
Cheers KW-rscos, PM sent. 👍
Old 31-08-2015, 01:24 PM
Anutternutter
Can I buy it then buddy? I've not heard from you yet? Cheers
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
wheelwizardrefurbs
18-09-2015 02:39 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: Map sensor question
