Fuel system for 500/550 bhp what's needed
Old 07-08-2015, 06:52 PM
ginner
ginner's Avatar
Default Fuel system for 500/550 bhp what's needed
As above I'm changing spec I take it the fuel system is on its knees at this power
What needs changing , lines pumps etc
Old 07-08-2015, 07:36 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I just have a 044 pump and a new fuel pump loom
Steve
Old 07-08-2015, 07:44 PM
Caddyshack
Caddyshack's Avatar
I have as above on 468bhp
Old 10-08-2015, 04:20 PM
turbotrev
turbotrev's Avatar
044 pump, good condition wiring and hosing, and big enough injectors.
And that's about it.
Cheers Paul
Old 10-08-2015, 04:39 PM
Mark Shead
Mark Shead's Avatar
For a bit more safety go for the dw350il.
Mark
Old 11-08-2015, 07:54 AM
jontysafe
jontysafe's Avatar
I've got a facet red top lift pump feeding a 1.5ltr swirl pot and 044 fuel pump. That pump that Mark mentions may be a good option for me. I wonder if I'd have to upgrade lift pump?
Old 17-08-2015, 01:33 PM
costina
Live long and prosper!!
costina's Avatar
Yes if you look up the specs on the facet they cant cope and only work due to the return filling the swirl pot.
I changed to a holley blue pump which was quieter in operation and greater flow rates.
Paul
Old 20-08-2015, 11:40 AM
jontysafe
jontysafe's Avatar
Paul
Thanks Paul, that's another thing I`ll be buying then. I wonder if that`s why I melted a piston!?
Old 25-08-2015, 08:39 PM
Mr RS500
Mr RS500's Avatar
Or you could just go OTT ,,LOL
Old 26-08-2015, 07:08 AM
Mark Shead
Mark Shead's Avatar
Are you monitoring fuel temp on that as that's a lot of heat going in to that fuel.
Mark
Old 26-08-2015, 11:44 AM
cozzy jeff
cozzy jeff's Avatar
mark the fuel won't get hot,it only drives on and off the trailer
Old 26-08-2015, 05:41 PM
Adam-M
Adam-M's Avatar
I spy a little cooler on the strut brace, that is a bonkers setup lol
Old 26-08-2015, 06:03 PM
Mark Shead
Mark Shead's Avatar
I think you will find that's the rear diff cooler.
Mark
Old 30-08-2015, 08:40 AM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
The pump you require depends on the boost you run. At 2.5bar your pump will need to be efficient at 2.5 + 3.5 bar = 87psi. Most are out of puff at this. Also the fuel you use is mega important the bsfc of pump is .6 change to Methanol & its 1.2 meaning twice the fuel needs to be pumped Race Fuel is around .9 meaning 50% more required. This is a subject I have studied. I was going to write a tech article on Pump/Injector choice at high boost its very interesting.
biggiejody
Insurance
02-09-2015 12:04 PM
taylora1409
12-08-2015 12:06 PM
marvin
Fiesta RS1800/RS Turbo
10-08-2015 11:14 PM
col93saphcos
07-08-2015 03:21 PM
Old ford
31-07-2015 06:50 AM
Quick Reply: Fuel system for 500/550 bhp what's needed
