ZF clutch type Differential
Old 05-08-2015, 02:21 PM
DaveCrack
DaveCrack's Avatar
Default ZF clutch type Differential
Does anyone know who does these diffs?
Already tried Bara but they only do Gripper.
Old 05-08-2015, 02:52 PM
Marc sierra
Marc sierra's Avatar
You can get relatively cheap clutch type LSDs in the US: http://www.mc2racing.com/products/xr...619/index.html
Old 05-08-2015, 04:14 PM
hEaT
hEaT's Avatar
Can vouch for these guys and their products. They're made for a 7.5" diff though, not a 7" as a heads up.
Old 05-08-2015, 04:56 PM
DaveCrack
DaveCrack's Avatar
That was the first option I thought about but dont like the idea of a cheap clutch type LSD. Also I cant find any good reviews how the Eaton diffs are set up in terms of ramp angles and if they can be serviced, as the friction plates are service items.
For ZF I know I can still get all service items cheap and local and its works fine in 2 of my mates cars.
Does anyone of you have a Eaton Diff fitted?
Old 06-08-2015, 06:22 PM
Thanasis
Thanasis's Avatar
Yes,me.
Old 07-08-2015, 10:24 AM
DaveCrack
DaveCrack's Avatar
Any words on how it works? Do you go out on track with it or fast road drivin?
Thanks!
Old 07-08-2015, 07:57 PM
Thanasis
Thanasis's Avatar
just for road use,and it is very good!!
Old 09-08-2015, 01:07 PM
RIB1122
RIB1122's Avatar
I've got a zf rear diff for sale!
Old 09-08-2015, 01:47 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Problem you still have is if you have a lot of torque the c.w.p still won't last
Old 09-08-2015, 05:46 PM
markk
markk's Avatar
What size and how much?
Old 12-08-2015, 03:57 PM
janvanv
www.rallyanarchy.com
janvanv's Avatar
Thanks!
To fit the Eaton diff a spacer for ring gear is needed..and the diff housing must be machined or ground on..making it thinner.
Spacer for the ring gear is not unheard of...I used one on a Saab gearbox we were using for rally and fitting a 5.15:1 final drive..
It was ground flat both sides...Despite repeated questions about the spacer, those guys selling this refuse to answer how their spacer is made..
Second;
Eaton is a 2 pinion diff--2 side gears, 2 pinions or planets....unlike all the ZF (and Gripper and Tran-X) I have seen in last 30 years.
Next: no pressure rings so no ramps at all, nothing..Only some spring pressure...
That makes it unacceptable in my book, especially at the price.
Finally there have been several outright failures with these...
And naturally not a word of post-failure analysis...
Vorsicht, junge!
DaveCrack (12-08-2015)
Old 12-08-2015, 05:20 PM
DaveCrack
DaveCrack's Avatar
Second;
Vorsicht, junge!
Thanks for the explanation! I always thought the Eaton unit looked kinda cheap compared to the ZF units used for BMWs etc. This now exactly explains why!
I am now gonna get a reworked BMW ZF diff and make it fit into the original Ford 7,5" housing.
chowfornow
14
05-01-2019 09:01 PM
arkeye
Ford Focus ST
20-02-2016 01:22 PM
01-11-2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
Quick Reply: ZF clutch type Differential
