Problem
Problem
Hi all need a bit help & advice.
On the way home from ford fair yesterday my speedo started playing up?
It was showing on 110 instead of 70? on average about 40mph out & bouncing
This has never happened before I pulled on the services to have a quick check on everything but all seemed fine, set off again & it started again??? If anyone could shed some light on this I would be grateful.
It's a staph cos 4x4
Cheers Lee
Cheers Lee
It is easy to remove the plastic drive. Check the speedo cable first but if it is the drive I have a spare that you can have...I think it's only 3 bolts but I cannot remember if you lose the front diff oil, prob would benefit from the change anyway.
If the oil has only just gone I then no harm in getting it out clean and refilling.
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
