How much power you got I'm sure your not out preform the 330's with 4 pots on the road
Hi James,
It's running 380bhp/400lb/ft as stated in first post
Was thinking the 6 pots are more for bragging rights as I'm not running 500+bhp nor doing track days but I just have an itch to buy once and buy right!!
Serious amount of cash though
Are the 4 pots enough or are 6 pots WAY better?
Never been in a car with either so would like anybody's opinion who has them/has experience with them.
Hi James,
Need to upgrade the rears at the same time so I'm guessing 300mm and 4X4 callipers is enough too.....?
I never had any issues with my 330's and 4 pots on the road with my saff at 500bhp and I'll be using them with 650! If needs be I'll change to bigger calipers. Your be fine with the 4 pots I'd save the money
Ap 6 pots in my car , brakes are unreal tbh ,
But I'm sure the 4 pots would be fine too ,
When u bought mine I was goin for the 4 pots but for very little more money I got the 6s
I've. 4wd caliper s on the back with grooved discs just
Cheers Dan. I see what u mean, not much difference in price so why not go for the 6's!
It may be overkill but was going to go 4 pots on the rear to finish it off nicely but haven't decided yet as I know 4X4 calipers and 300mm discs should be sufficient.
If you go 4 pots on the back you ll prob need a brake bias fitted ,
You sure the diamonds will fit over the brakes ?
I always thought they wouldn't
Ya they're a balls to fit but apparently Paul_RS on here said before if I remember correctly that they will fit with a little effort. Apologies if quoting incorrectly on that one!
Ap 4 pots on the back of a road going 2wd saff like yours will leave you spinning down the road Phil.
I was going to do the same and was advised by mike rain bird that it's a no no on 2 wd
Ya that's sound James. Read up a lot more on it and seen Mike Rainbird posting about it too saying that even his car at 180+ mph only had 4X4 calipers and bigger discs I believe on the rears...said he had no problem ever with them.
Think I'll just go with that, 4X4 calipers, 300/320mm discs MT Motorsport on the rears and either 4 pot / 6 pot on the front.
