1987 Sierra xr4x4 help....
Old 10-06-2015, 10:11 PM
Porkzilla
Porkzilla's Avatar
Default 1987 Sierra xr4x4 help....
Hey!
recently i traded my 91 sierra 2.0l dohc into a 87 xr4x4 that dosent run, the engine in the car is the 2.8i kjet
Well, the car does not want to start at all, it turns around very nice, but no sign of life, it backfires HEAVY if i press the gass, 1 time a flame came out of the exhaust.
the spark plugs are new, leads, and coil...
Iv checked the sparkplugs 3 times and they get wet, and iv checked for spark and the spark is very good, so what can be wrong now ?? I lined up syl 1 TDC and checked the dizzy, sat the ignition at 12 degree and still no life....
The car has run good all the years and the old owner parked the car and the next day it wouldent start...
Sorry for my english, im norwegian
Old 11-06-2015, 08:59 AM
rdvil
rdvil's Avatar
All the plugs equally wet?
Old 11-06-2015, 11:06 AM
Porkzilla
Porkzilla's Avatar
It looks like it yea. I can hear the fuel pump when i turn the key.
Old 11-06-2015, 11:12 AM
dojj
Resident Wrestling Legend
dojj's Avatar
Fuel flap in the metering head or the cold start injector on the side of the plenum chamber
Disconnect this and see if it's any better
Old 11-06-2015, 03:58 PM
Porkzilla
Porkzilla's Avatar
Where is the metering head ? nr 15?
Old 11-06-2015, 08:50 PM
doga-ot
wesskitzo
doga-ot's Avatar
Yep 15 is metering head!
Old 11-06-2015, 09:53 PM
dojj
dojj's Avatar
And the thing above 35 is the cold start
It was normally blue from memory so just unplug the electrical connection
Old 17-06-2015, 07:02 PM
Porkzilla
Porkzilla's Avatar
Ok an update, i managed to break a screwdriver's tip inside syl nr 1... but thats fixed, iv checked the timing, gapped the plugs, adjusted the timing to 12degress but still no start.... What's going on with the old girl :s how do i check the aux valve and metering head ? and the warmup regulator
Old 17-06-2015, 07:52 PM
Porkzilla
Porkzilla's Avatar
I GOT THE CAR RUNNING! the fucking old owner had the dizzy 180 wrong! It fucking started at 1 turn
Old 17-06-2015, 08:47 PM
dojj
dojj's Avatar
The simple things eh
Old 17-06-2015, 08:55 PM
Porkzilla
Porkzilla's Avatar
yea, but i was kinda lazy after 12h work day so just made up this
1-5. 4-3. 2-6
The engine thinks syl 5 is 1 and 4 is 3 and so on runs like a charm now, going to fix it tomorrow.
chowfornow
14
05-01-2019 09:01 PM
01-11-2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
03-10-2015 10:44 PM
Fil
30-09-2015 12:08 PM
SMILER258
28-09-2015 09:04 AM
Quick Reply: 1987 Sierra xr4x4 help....
