Fuel flap sticking out ??
They can be adjusted but I think this may be down to the flap being pushed out to far and bending the hinge. So I'm going to try and bend it with out it breaking
I do have a spair so if it go bang it's just 1 more thing to paint
I had a similar problem on mine, it used to flap open when driving on the motorway as well. Check in the boot area where the emergency fuel release is and see if all connected properly
It's sitting fush in the cut out but it sticks out wher the hinge is
Iv only just fitted the flap as the shell had been striped I can't see any way of adjusting it
Resident Wrestling Legend
then it'll be the housing the thing sits in thats not in properly
there were loads of tiny little mods to the panels as the sierra progressed over the years and it's a case of trial and error
if the internal casing fits snug then it will only be the flap itself that is bent out of shape, but they were a bitch to fit in the first place, i had loads of issues when i did this to the estate with cable runs and stuff and it eventually meant a whole strip down of all the panels inside to get it to fit right
there's also the internal handle so you can open it from inside the boot, but not all of them came with them so it's worth hunting for one with it, i used a bit of wire eventually when mine broke
07-10-2015 12:56 PM
