Newbie - 4x4 propshaft hex rubber
Hi, ive not had my 1990 4x4 saph long. I am getting a slight vibrating on the back end when high up the rev range and upon inspection have found the hexagonal propshaft rubber demolished which i am assuming is the most possible cause.
I have looked around and these are near on impossible to find?
Can anyone point me in the right direction for a replacement part or available conversion to a newer type?
Thanks in advance
Thanks in advance
From looking into it the escort ones are totally different.
Youve got to change the output shaft bolts and change the front section of the rear prop to an escort one which aint gona be cheap!
Surely someone has manufactured replacement rubbers or offers a conversion kit... this must be a common fault?
This is a pic I've found on the forum of an escort rubber fitted to a saph... The shaft centres don't connect In any way.
Totally different as the saph one has a bush to insert the prop and the escort one doesn't as the escort prop is a different end.
https://cimg5.ibsrv.net/gimg/passionford.com-vbulletin/2000x1124/80-20150517_130843_2c8030b998da83e09971ce89b1a82b4d48 07e760.jpg
That picture is wrong !!
You cannot have it like that .
Either prop locates in donut and on the gearbox as per hexagonal one
Or
Prop locates back of gearbox with the circular donut around it as per escort cosworth
Or
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
