2wd sierra cosworth noise issue
Old 25-04-2015, 10:57 PM
Thanasis
Thanasis's Avatar
Default 2wd sierra cosworth noise issue
Hello to all,i have a 3dr sierra cosworth,and i have a noise for example with 4th gear from 3000rpms - 2600rpms when i leave the throttle ,from under the car about in the end of gearbox and in the rear place like grrrrrrr like something metalic part have vibration or something knocking and comes noise, all the parts are new, drive joints,rebuild prop-shaft with all new,rebuild gearbox,rear diff with 65000km,wheels bearings new,also i tested the car with SAE140 gear oil and the noise still there,so does anyone had the same issue?any idea? thanks in advance
Thanasis
Old 26-04-2015, 02:56 PM
costina
Live long and prosper!!
costina's Avatar
Exhaust hitting floor pan??
Centre prop mount tight?
Handbrake cable loose?
Old 26-04-2015, 03:16 PM
Thanasis
Thanasis's Avatar
Εxhaust no hitting floor etc..
centre prop mount have new bearing
Handbrake cable is ok also
At 99% is inside the diff from planet gears,in this place is weak with result the gears plays when the drive shaft works without load,i tested the car today in the rear wheels on air with the 4h gear at idle and after i catch the right drive shaft with hand and the noise stops!
Old 26-04-2015, 03:18 PM
turbotrev
turbotrev's Avatar
I had an apparently rebuilt gearbox when I bought my car last year, weren't sure what it was at first and thought it was the exhaust vibrating.
It got noisier and noisier till eventually I couldn't select gears easily and the bearings had completely gone in the gearbox.
It made awful noises on overrun and at certain revs
Cheers Paul
Old 26-04-2015, 03:29 PM
Thanasis
Thanasis's Avatar
Cheers Paul
Ι don't have awful noise,just when i leave the throttle about 3000-2600rpms just one like 'gourrrrr' and the noise comes from the rear and right side of the car,thanks
Thanasis
Old 30-04-2015, 09:26 PM
AndyPen
AndyPen's Avatar
I had a really weird experience with my sapphire with a similarish noise - it turned out to be the starter motor of all things!
charliecosworth
19-08-2015 02:00 PM
cossie4x4
14-08-2015 06:29 PM
155lee
14-08-2015 11:21 AM
adam151082
11-08-2015 04:50 PM
Quick Reply: 2wd sierra cosworth noise issue
