6 degree beam
Old 19-04-2015, 10:19 PM
Sierrasideways
Sierrasideways's Avatar
Default 6 degree beam
Best place for A: value for money as I've heard places differ in the region of £600!
B: Quality of workmanship
Anybody seen any differences anywhere?
I have the cash, just want to spend it in the right place.
It's for a crystal blue.
Cheers.
Philip.
Old 19-04-2015, 10:37 PM
Sonic Boom
Sonic Boom's Avatar
IMHO MK Motorsports one is the best.
Rich
Old 20-04-2015, 04:06 PM
Sierrasideways
Cheers Rich
Old 20-04-2015, 04:08 PM
james kiely
james kiely's Avatar
phil ,my buddy got one made by richard up in armagh and the quality is very good
Old 20-04-2015, 04:36 PM
Sierrasideways
Sounds good James.
I believe that one is much cheaper than MK Motorsports one so just wondering why?
What's the major differences?
I just want to spend the money in the right place.
Old 20-04-2015, 04:41 PM
Fezman1
Fezman1's Avatar
Is that the guy in Ballygawley? If so I got a beam from him. Very well done and well priced. Uses quality rose joints & fabrication was spot on. He even gave me group A tarmac camber and toe settings for setting the car up after.
Old 20-04-2015, 05:27 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
There's lots who make them now but you need to choose one that's not going to make your car handle worse lol I'm going to get an mk one
Old 20-04-2015, 09:18 PM
Ade
Fast Ford snapper
Ade's Avatar
How would any make your car handle worse?
Surely it's just adding adjustability to the rear end, so handling will be as good as the set up?
Correct me if I'm wrong, and there's genuine design differences, but I would expect that build quality would be the only issue?
Old 20-04-2015, 09:22 PM
ajamesc
ajamesc's Avatar
I've been looking into what beam to buy for a while now and read a fair bit! Seems it's not in common for a few cheaper home made beams to not be genuine 6 degree beams and they can make the car feel worse than standard on the limit. I guess you get what you pay for. Any one can buy a welder and make one don't mean there doing it right lol
Old 20-04-2015, 11:04 PM
james kiely
Originally Posted by Sierrasideways
Sounds good James.
well phil i have a mk beam with a jag diff and its of excellent qualiity,which cant be denied .
i have been to richards workshop and seen his fabrication/welding first hand and the quality is excellent also.
thats the chap , great value for money without any compromise in fabrication standards
Old 21-04-2015, 06:59 AM
Marc sierra
Marc sierra's Avatar
I have also put quite a lot of time into finding out what different beams are available. I did notice that one of the beams that was available was not 6 degree, but probably more like 13 degrees (compared to the 18 degrees which is standard). But I don't see how they would make the car feel worse than standard. Reducing the angle is still an improvement, it's just not as good as it could have been if it really was 6 degrees. In the end I chose to go to a local welder and have my own made. And I do believe I did it right.
Old 21-04-2015, 07:10 AM
MK MOTORSPORT
MK MOTORSPORT's Avatar
Cheers.
Philip.
hi phil
as well as price ,look at what you get for your money ie single /double adjustable ,size/ quailty of rose joints ,uprated coil over mounts ,adjuster assembly on inner arm for adjustment in the slot ,also is it mig or tig welded ,has the arm been seamless tubed on the inside before it was skinned etc
mark
Sierrasideways (23-04-2015)
Old 21-04-2015, 08:03 AM
Fezman1
Fezman1's Avatar
Originally Posted by MK MOTORSPORT
hi phil
mark
I must admit- your inner arm adjuster is a great thing.
Most people use McGill motorsports rod ends- & the 'premium' range ones.
Original arm ends are mig welded - so mig welding any changes is perfectly acceptable.
The original arms are hopelessly weak- so any strengthening (without too much compromise on weight) can only be a good thing.
The thing people forget about altering a beam and arms is the time. even with proper jig sets - it still takes a good few hours to complete. & this is where some of the cost differences come in.
As said before, going to an adjustable beam (of any) wont make your car handle worse - unless you make a pigs ear of setting it up.
Old 21-04-2015, 08:30 AM
london_chris
london_chris's Avatar
so, i am looking on behalf of a mate, these beams, can someone list a name of company or suppliers and price so a comparison can be made.
thanks in advance.
chris
Old 21-04-2015, 09:17 AM
MK MOTORSPORT
Thankyou
I think it helps makes it easier to adjust
I meant mig or tig as in tig is slower to do as in time/cost
I use 7/8ths joints witch are very big ie stronger
You have to use jigs to keep everthing square and true
I usally takes a day to do beamg and another day to do a pair of arms
Mark
Old 21-04-2015, 09:23 AM
turbotrev
turbotrev's Avatar
How much are your beams Mark?
Cheers Paul
Old 21-04-2015, 01:18 PM
MK MOTORSPORT
Cheers Paul
Top of the range one
£1000
Mark
turbotrev (21-04-2015)
Old 21-04-2015, 01:53 PM
Danielbetty
Danielbetty's Avatar
Scs all day long
Old 21-04-2015, 09:59 PM
Hellraiser
Hellraiser's Avatar
I have MK motorsport one, work in it is perfection, as always from him!
I bought lots of fabricated parts from Mark bcos he always explains to me how they work, what difference they make, the benefits of having them, i seriously cannot fault his work or knowledge
Old 23-04-2015, 07:33 AM
Sierrasideways
Default MK Motorsport it is...
£1000
Mark
Hi Mark,
Thank you for the information. All I've heard are good things about your beam so I know where I'll be spending my hard earned dosh
Cheers,
Philip.
p.s. Thanks everyone also for the replies.
Old 23-04-2015, 07:55 PM
Paul_RS
Paul_RS's Avatar
SCS/Bayjoo beam is the best one IMO.
Old 23-04-2015, 08:19 PM
Caddyshack
Caddyshack's Avatar
Why didn't Ford make the beam 6 degree before production stopped, is the a down side other than cost?
If you drove 2 identical cars on the road, could you tell a non equipped car from a 6 degree car straight away?
Old 23-04-2015, 08:38 PM
ajamesc
ajamesc's Avatar
Was there not a slight difference with the rs500 beam? I'm sure I read something on here with the North Yorks caltex one
Old 23-04-2015, 08:51 PM
Mark Shead
Mark Shead's Avatar
Yes.
Mark
Caddyshack (24-04-2015)
Old 24-04-2015, 08:57 AM
Caddyshack
Caddyshack's Avatar
Originally Posted by Mark Shead
Yes.
Mark
Damn You!, Shead....another £1000 I need to spend.
Old 24-04-2015, 09:31 AM
R4N SS
R4N SS's Avatar
whats the difference between an MK and SCS beam - surely they are the same and its just the fabrication that is different?
Old 24-04-2015, 11:09 AM
onslack
onslack's Avatar
ive got a turbo systems 6 degree beam fitted to my saph, it made a massive difference to the way the car drove and put the power down
my beam bushes were like wizards sleeves though so were due to be replaced
Old 24-04-2015, 11:41 AM
MK MOTORSPORT
Hi mine are double adjustable , ie rose jointed both ends , then mine have a billet type motorcycle chain adjuster to make adjusting inner joint easier
And i uprate the shock mount for coil overs
Mark
Old 24-04-2015, 12:56 PM
Marc sierra
The one that isn't actually 6 degrees if I remember correct...
Old 24-04-2015, 01:51 PM
Danielbetty
Scs uprate the mounting points for coilovers as well
Old 01-05-2015, 05:02 AM
R5FORD
R5FORD's Avatar
Is the price including a beam or do i have to supply it?
Old 01-05-2015, 08:57 AM
Caddyshack
Caddyshack's Avatar
supply or exchange normally
Old 01-05-2015, 10:35 AM
Sierrasideways
I was told exchange also.
Old 02-05-2015, 03:53 PM
Mark V8
Mark V8's Avatar
What are the 6 degree beams like for road noise and vibrations being fully rose jointed ?
Old 02-05-2015, 04:06 PM
MK MOTORSPORT
hi
the standard bearings are rose jointed in effect ,spherical bearings with rubber seals in the end
mark
Old 02-05-2015, 04:12 PM
Mark V8
Mark V8's Avatar
hi
mark
Thanks Mark
Do you offer a version with some kind of rubber to protect the joints ?
Also for the Jag beam do you need the diff as well ?
Thanks
Old 02-05-2015, 04:27 PM
MK MOTORSPORT
Thanks Mark
Thanks
Can fit rubber boots on joints
If you wanted to fit a jag diff yes i would need diff
Go supra bolt in
Mark
Old 02-05-2015, 04:32 PM
ajamesc
ajamesc's Avatar
Do you use rose joints with grease nipples to keep things lubricated
Old 02-05-2015, 05:18 PM
Caddyshack
Caddyshack's Avatar
I thought rose joints should not be lubricated, the surfaces were designed not to be and grease encourages dirt to become a grinding paste. I could be wrong though
Old 02-05-2015, 05:20 PM
ajamesc
ajamesc's Avatar
I work on a fair few tippers and skip loaders with smaller rose joints on the back for the sheet and tipping gear. They all have grease nipple types.
Quick Reply: 6 degree beam
