oil squirt jets
No you don't have to, I used a 4x4 pump but you do have to block off the original oil spray bar outlet on the pump, I machined up a small alloy bung and pressed it in flush to the pump, where the little piece of tubing on the oil pickup pipe goes into the pump, and I also cut off the little piece on the oil pickup pipe itself (along with the original oil spray bar pieces).
deathrider666
28-09-2015 06:12 PM
