ABS / brake loom questions
After many years on this build its time to connect the ABS loom, if only I could remember all the bits...
Can you guys identify where this plug should go to ? Is it to dash lights ?, If so I never did get that light setup, if anyone has it please let me know.
And the top plug on brake master oil tank, i think it must go to car loom and duplicates reading from ABS loom on other side ?
And I remember there was a connector on bottom motor with two terminals, where did that go to... the connector is long gone.
And the brake lines, I think I just run three lines as so, if you have a pic of what yours looks like it will help me get it correct. (putting stainless lines in)
JK12
33
26-04-2021 12:09 PM
