Afr readings ?
30-03-2015, 03:01 PM
3-door moonstone
Afr readings ?
What should the afr gauge be reading at idle ,cruising, and on boost
Can't get car in for rolling road session till may so want to know what should be reading till then
30-03-2015, 03:29 PM
PassionFords Creator
Purely a rough guide but reasonably safe for mooching around...
13-14 AFR at idle and low load
12-13 AFR under light to medium load
11-12 AFR under very high load.
Your mapper will correct from there for safe hard use.
30-03-2015, 04:20 PM
3-door moonstone
Quote:
Originally Posted by
Stu @ M Developments
Cheers bud just booked it in with you in may
31-03-2015, 07:31 AM
siscossie
Thank you. Soon have her running perfectly for you.
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
07-10-2015 12:56 PM
Iain Mac
30-09-2015 09:39 PM
20/20 vision
29-09-2015 11:27 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
