Saff cossie 4x4 rear wheel bearings
Received 1,042 Likes
Are the rear wheel bearings on a saff cossie 4x4 the same as any other sierra or granada. I just think some of the bearings ive seen have a bit of cossie tax on them.
Paul_RS (16-03-2015)
The following 3 users liked this post by Turbosystems:
I bought from http://shop.grahamgoode.com/wheel-bearings-21544-c.asp and yes they are sold left or right.
Only difference for left / right side is that the central nut is LH or RH threaded, bearings are the same
Fart of the Purniture
Before I buy any more bearings I was hoping they might be the same?
Does anyone know without guessing?
Well that's good!
The same as what I was told a while ago...
BUT there's a tasty 3dr on here and the geezer did a 5 stud conversion to it, he said the Granada hub wouldn't fit the 2wd Cosworth steering knuckle, so he had to re-drill the 2wd Cosworth hub.
If the bearings are the same then you should be able to swap the hubs but apparently not.
Unless I'm missing or not understanding something?
Sorry Mike, it appears I have made this confusing due to me not being specific with my questions.
I have a full set of bearings that I bought for a 24v Granada. (2wd)
I was later told that they would fit 2wd Sierra Cosworth steering knuckles/hubs.
I now am confidenet after the replys in this thread that the rear bearings will be fine.
It's the front wheel bearings that are now my question.
Will the 24v Granada (2wd) front wheel bearings fit the 2wd Sierra Cosworth steering knuckles/hubs?
I do go around things the long way sometimes - I'm sorry
Anutternutter
21-08-2015 06:07 PM
mrmann
20-08-2015 11:24 PM
