Stripping engine
11-03-2015, 06:07 PM
Stripping engine
So over the last week also, I have stripped out engine.
I was just after confirmation on turbo identification;
T34?
Also are these 4x4 Pistons?
The block
11-03-2015, 06:17 PM
I was just passing through. Going to fix the links, but the pictures are waaaaay too big. You need to resize them.
11-03-2015, 06:26 PM
11-03-2015, 07:14 PM
yeah
Sadly I can't help you in your questions. Hopefully someone useful will be able to shed some light.
11-03-2015, 07:19 PM
No worries at least we got picture issue sorted!
11-03-2015, 08:33 PM
I would say yes to both questions... The pistons look like mine, not that I could tell the difference between them an 2WD!?
Had a little bit of valve contact there!? Good luck with the build...
11-03-2015, 08:46 PM
Quote:
Originally Posted by
cossiestu
Yeah, I thought that, would that be an over Rev, timing out or wrong cams.
11-03-2015, 09:12 PM
The turbo looks like a T3?
Pretty sure the pistons are 4x4.
Block could be a YBP one as it has the oil jets?
11-03-2015, 09:20 PM
Live long and prosper!!
Paul_RS
I'm with Paul on this
4x4 pistons have a offset piston pin.
oil jets means
cheaper pinto pump can be used woohoo
11-03-2015, 09:27 PM
Paul_RS
I stand corrected! ...No little oblong bit where the Garrett badge thingy went. Sorry to mislead....
11-03-2015, 09:28 PM
Caddyshack
Reminds me, of when I built mine, I didn't get the pistons pocketed!? Nob.
11-03-2015, 09:49 PM
Thanks for your help guys,
Only want to identify turbo as I am going to sell it, so need to get it right!
Also I will be putting pocketed Pistons back in (not sure as to what brand yet...?)
Interested about oil jets, it has high pressure YB oil pump in it, is there anything I can do whilst engine is apart to ensure I'm getting best distribution of oil into the bores?
19-03-2015, 10:34 AM
Are the 'WRC' jets that are available any different to the ones that come factory fitted on The block?
If so is it worth changing them?
19-03-2015, 06:08 PM
Use what u have just fully clean.
Paul
19-03-2015, 10:12 PM
Topjoe9
43
14-09-2020 09:29 PM
Wilsfoci
15
30-03-2016 10:26 PM
20-08-2015 09:21 PM
track.focus'd
12-08-2015 05:53 PM
