hall effect for yb
Old 10-03-2015, 09:45 AM
oohogwash1
oohogwash1's Avatar
Default hall effect for yb
I am looking at configuring my sync signal with hall effect sensor.
Similar to the one shown below, does anyone know where I can source the attachment for camshaft and the sensor, the sensor looks like escos item but I am not sure.
Regards
Gavan
Old 10-03-2015, 12:06 PM
lacey
lacey's Avatar
Piero at xpower sell them
He also sell a lot on eBay
Old 10-03-2015, 11:28 PM
oohogwash1
oohogwash1's Avatar
thanks i have sent message to him
Old 10-03-2015, 11:47 PM
markk
markk's Avatar
IF you are on OE management then a Hall sender will not work. Needs to be inductive (VR).
I do have a Hall sender on mine but not on factory ECU.
Old 11-03-2015, 09:40 PM
oohogwash1
oohogwash1's Avatar
Its a motec aftermarket which supports both mag and hall effect, folloing Mark Sheads response on escos forum (I asked there too) I am using the mag. The option of grinding of one lobe of the distributor is still there too. Just depends on tuner he does not like the dizzy approach but I think he is confusing the the setup with some other setups and my dizzy has a bit of slop in bushes so not sure how much it costs to refurb hence the sensor approach.
I have not sighted a mount for hall effect in responses, if you know of one let me know please.
Old 11-03-2015, 09:57 PM
markk
markk's Avatar
The hall is far more accurate from an electronic perspective, been there done that on a yb.
Hence now on a hall sender.
Old 11-03-2015, 10:14 PM
oohogwash1
oohogwash1's Avatar
Mark, can you send me details of how you set it up please... I will follow your lead, it keeps the tuner happy also
Old 11-03-2015, 11:05 PM
markk
markk's Avatar
You will need to find a suitable sensor, i bought a generic Honeywell hall sender amd made an adapter to bolt it in.
Wiring is simply sensor 5v, sensor ground and a signal in.
Use the wrc cam trigger with one tooth.
Old 12-03-2015, 02:15 AM
oohogwash1
oohogwash1's Avatar
so the trigger of Piero at xpower is still the correct one, I just make a sensor bracket to suit
Old 12-03-2015, 07:00 AM
markk
markk's Avatar
Yes, that's it.
Old 12-03-2015, 09:01 PM
oohogwash1
oohogwash1's Avatar
Mark, I am retracing your steps to make the hall effect mount and source sensor. Can you advise where you sourced sensor or what it looked like / part number and what you did to make the adaptor please. It will at least let me know a way that works. I would like to finalise the order with xpower too. I just bought his bits , will modify for hall effect, keep his mag bits as backup.
Gavan
Ford Focus RS Parts for Sale.
02-06-2016 06:46 PM
Rod-Tarry
237
18-03-2016 09:13 PM
pabloXR
21-09-2015 12:42 PM
Quick Reply: hall effect for yb
