air injector plumbing
The housing is important to get right as there's a small pin hole in one side that allows air to bleed off. The hole is on the blanks fitted to the right hand side.
It's been years since I fitted mine, but I think the blank with the hole should be on the actuator feed side, so the top on your photo.
It also looks like your pipes are wrong as well? Pretty sure the compressor housing feed should go to the top of the injector, not the bottom as on your photo.
I could be utterly wrong though
Johnny Knoxville
30-09-2015 07:21 AM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
Russ Payne
25-09-2015 08:29 PM
