Safe boost for Hybrid T3
20-02-2015, 10:03 PM
I have a YB 8:1 CR running Emerald ECU with 550cc injectors, 3 bar map, mls head gasket with Victor Rienze head Bolts, what would be the max boost pressure I can run a T3 hybrid and what sort of power could I realisticly expect?
21-02-2015, 07:49 AM
Reliable 300bhp on a t3 at 19-20psi.
Others have run more boost but not sure how long the turbos last.
21-02-2015, 08:01 AM
Sponsor
Quote:
Originally Posted by
Ridgey
Plus the back pressure and heat above 20 psi could cause engine damage as my son was insistent on running 26 psi and ended up burning 2 exhaust valves out
21-02-2015, 08:33 AM
Mine peaks at 26 psi then drops down. Its been like this since its been mapped over 3 years ago.
21-02-2015, 08:39 AM
Mine peaks 26psi to MSD set it up over a year ago, 356bhp on there dyno
21-02-2015, 08:41 AM
Live long and prosper!!
when you say hybrid what spec? I have seen 336bhp from a T3 on a 4x4. which was peaking around 25 dropping to 21 ish. that was in 2006.
22-02-2015, 12:17 PM
Adding a comment so I can follow this thread
I've got a stg1 turbo technics T3 fitted and hoping for 330. If it blows up I'm not arsed, I'll pull it to bits again and go bigger
22-02-2015, 12:25 PM
Tinshaw
356 bhp on a T3??
That must be the most BHP ever on one ??
22-02-2015, 12:26 PM
I had a stage 2 TT T3 on my old 3dr peaking @ 2bar on a NMS live map, great punchy setup that was
22-02-2015, 12:50 PM
Sponsor
Staffi
356 bhp on a T3??
And there is going to be some monster heat going ion there lol
22-02-2015, 01:13 PM
Jay,
Defo Jay, and longevity of about 2 hrs turbo life
22-02-2015, 03:09 PM
James set it all up October 2013 & it's ran perfectly ever since, I've bought a T34/63 to go on next with 55s as James recommended.
22-02-2015, 03:57 PM
Staffi
356 bhp on a T3??
Seen a T34/48 produce 346 on greens and that was on the limit.
22-02-2015, 04:02 PM
costina
This thread is about a T3 Paul
I worry about you sometimes
Edited to say,
I wouldn't have thought a T3 could flow enough to make nearly 360 bhp tbh, ( hybrid) or not, may be wrong of course
22-02-2015, 04:06 PM
Staffi
Edited to say,
That's why I put it seems high for a T3
I worry about me too mate
22-02-2015, 04:56 PM
costina
Ha ha, two shay
Surely this has to be wrong?? Do you have a graph for it Tinshaw??
22-02-2015, 05:27 PM
I must hang my head in shame.....
I've just got the graph out its 336.9 so appologees gents.....!
22-02-2015, 05:32 PM
22-02-2015, 05:34 PM
Women always tell me I get my mm & inches the wrong way round to!!!!!!
22-02-2015, 06:09 PM
Tinshaw
This is why you never let your wife/girlfriend order carpets.
They end up too small
22-02-2015, 06:27 PM
Sponsor
costina
Its our fault because for years we have been telling them that
THIS BIG IS 9 INCHES
24-02-2015, 09:59 PM
saphcosmike
In my experience you'll be extremely lucky to get 330 out of a T3. You need a t34 to make that power.
timsrs
13-11-2018 11:48 AM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
