Plenum spacers 10,14,17mm ????
20-02-2015, 09:37 PM
Just browsing ebay and saw these three sizes advertised, (10,14,17mm)
I have an eec IV inlet going on my build and figure one of these will be good.
I had heard the 10mm was worth getting, never seen 14 or 17mm presented.
Has anyone got or heard any feedback on the value of these items (all sizes).
Thanks
Gavan
23-02-2015, 10:57 AM
cover
i have a 14mm well engineered conversion works well with supporting mods-even looking at the flow from t/b far more space-its very restrictive standard
i have a whole kit for sale-will try and put better pics of the cover up later today
24-02-2015, 11:23 AM
I remember something about the 10 mm could be a pain to fit, whereas the 14 mm is plug and play - relating to the fuel rail, somehow.
24-02-2015, 02:17 PM
Happily retired
Quote:
Originally Posted by
Heitmann
14mm is the lug width so it fits straight on.
24-02-2015, 06:05 PM
14 was a perfect fit on my ST.
25-02-2015, 12:31 AM
I will go for a 14mm, thanks guys, did you notice any difference seat of the pants or dyno wise ?
25-02-2015, 01:01 AM
Didn't know you could get 17mm... Do these make that much difference to performance?
25-02-2015, 03:51 AM
Tidied a few things at once, don't know how much of the improvement the spacer made.
25-02-2015, 06:05 AM
I would be interested in how much better the engine performs with these spacers too.
26-02-2015, 10:39 AM
I bought one last week, 14mm, just waiting for it to arrive.
I might chuck it on before the live map, can only help.
My only question now is, the plenum cover has moved so the support bracket no longer lines up, how do you get around this?
26-02-2015, 11:33 AM
Support bracket? Is that the one that bolts to the engine mount? If so i took mine off bloody years ago.
26-02-2015, 04:03 PM
got a 14mm on mine too, also modded the restriction out of the elbow
26-02-2015, 04:14 PM
Anembo do 10,14,and 17mm ones ,got 10mm on mine seems to make a difference
26-02-2015, 05:25 PM
Same here! Don't think it was even fitted properly before I had the car, as when I took the head off, i wasn't attached to the mount, as it just lifted off....
26-02-2015, 08:26 PM
Just chuck the fooker in the bin lol.
26-02-2015, 08:31 PM
I kept mine, looked a handy looking bit of metal!?
26-02-2015, 08:41 PM
when you say seemed to make a difference, where do you think it effected.
i understand its subjective
26-02-2015, 09:59 PM
Im guessing the spacers are made of a phenolic/other none thermal conductive material to stop head getting to the plenum? Reduced IATs and all that as well as better flow.
26-02-2015, 11:53 PM
cossiestu
My plenum cover has the original M5 stud which passes through the bracket for a nut.
If a spacer is added the bracket won't align, so another problem to sort.
27-02-2015, 05:10 AM
saphcosmike
I made a 14mm longer bracket from a piece of angle.
01-03-2015, 11:48 AM
Cake lover!
Glenn I guess you have never seen the head crack and snap off from not using the bracket?
03-03-2015, 04:27 AM
03-03-2015, 07:27 AM
Happily retired
oohogwash1
Many years back in the late 1990's a 14mm spacer made 10bhp on a 400bhp conversion its the only test ive heard of.
03-03-2015, 07:27 PM
03-03-2015, 07:33 PM
Is that right Rodney.
I did a back to back on the engine dyno about 12+years ago, It was on a T34 making 400hp it made no more HP at max as turbo was flatout but up to max it made 10hp and 10ftlb more through the range.
Mark
03-03-2015, 09:09 PM
Happily retired
Well nearly right. Mark has told the full story, I was close considering my age
. I remember the 10bhp gain but Mark has pointed out not at the topend.
04-03-2015, 07:39 AM
So the spacer gained more power through the rev range but not at the top of it.
I might invest in a spacer.
04-03-2015, 07:42 AM
The turbo was to small. A bigger turbo would have made more.
Mark
04-03-2015, 07:47 AM
Did Someone Mention TUV
I borrowed Rod's spacer on my GT30 conversion. Made a big difference. More fuel had to be added to compensate.
04-03-2015, 08:04 PM
Mark Shead
Mark
Thanks for that info Mark.
04-03-2015, 09:26 PM
So is a 10mm one on a saph with a t34 .63 Siemens and. Bd14 inlet worth having Mark?! I have one and yet to be mapped so if I would get more through the Rev range would be worth using, not like top end is used as much as we'd like lol.
Apreciate your input
05-03-2015, 07:42 AM
There will be no harm in fitting it imo.
05-03-2015, 08:29 PM
I was going to originally then told by a few tuners it wasn't worth it unless going bigger than t34, but I've had it kicking about for ages and engine is out the car for its resto so could fit it when I give the engine a freshen up....
05-03-2015, 08:33 PM
Toe Knee
If you have it and its getting mapped then it is a slight benefit.
Mark
05-03-2015, 08:35 PM
It can make it slightly softer on response if you go to big.
Mark
05-03-2015, 09:14 PM
is 14mm a safe size ? (not too big like 17mm) I have eec1v plenum
05-03-2015, 09:35 PM
oohogwash1
Yes it's fine.
Mark
06-03-2015, 04:38 AM
So will tje fueling need to be checked after a spacer is fitted.
06-03-2015, 06:49 AM
Yes.
Mark
09-03-2015, 09:02 PM
Mark Shead
Mark
Thanks for the info mark
Be a while before ive done my resto though lol, you don't make standard Ecu's do you from memory?!!
steve.rst
15-03-2016 08:01 AM
stephenb4506
33
02-10-2015 06:25 PM
mondeomark
28-09-2015 06:28 AM
IainRS1700T
25-09-2015 06:44 AM
timsrs
22
24-09-2015 08:14 PM
